e-Way Bill & e-Invoice – FAQ
This page lists all the FAQs related to e-Way Bill and e-Invoicing in TallyPrime.
As per GST rules, when the Transporter ID is provided in e-Way Bills and e-Invoices, then the Vehicle Number need not be provided.
This rule has been implemented in TallyPrime Release 3.0. Thereby, if your e-Way Bills or e-Invoices contain the Transporter ID but not the Vehicle Number, they will be recorded seamlessly, without going into Uncertain Transactions.
Currently, NIC has provided relaxations for e-Invoices and e-Way Bills. The notifications are available in the below links:
You can cancel e-Way Bill and e-Invoice from TallyPrime, only if those are generated in TallyPrime. If you have generated them from anywhere else, you can proceed for cancellation from the portal.
You need to check whether the the cancellation details are already exchanged with the portal. If it has already been done, then you will not see the options to cancel e-Way Bill and e-Invoice again in TallyPrime.
Yes, the cancellation details for both the e-Way Bill and e-Invoice will be saved even if you pressed No while exchanging the cancellation details with the portal.
If you are in TallyPrime Release 7.0 or later and generated e-Invoice with TallyPrime, you will be able to verify the IRN Generation Date & Time from the e-Invoice report. Depending on the time limit of 24-hours, you will be able to see the cancellation details for the e-Invoice.
If the 24-hours time limit has not exceeded, you will be able to see the cancellation details and proceed for the cancellation of e-Invoice. If the time-limit of 24-hours has not exceeded, you will be able to see the cancellation details but will not able to cancel the e-Invoice. In such a case, you will have to pass a Credit Note against the e-Invoice.
This is applicable for e-Way Bills generated with Part B details, as well.
Yes, it is possible to cancel or delete the voucher in your Company Books. Press Alt+X or Alt+D, and then proceed accordingly.
No, the cancellation details will remain in the voucher, and can be exchanged with the portal for the cancellation of e-Way Bill and e-Invoice. The voucher will be retained in the Company Books.
Yes, you can cancel the e-Invoice from TallyPrime only if you are cancelling within the 24-hour time limit.
