How to Use TallyHelp
As a businessman, every minute counts. When you have a question about TallyPrime, you shouldn’t have to spend time waiting for support, or figuring things out on your own. TallyHelp is designed to give you the right answer, at the right time, in the way that’s most convenient for you.
Whenever you need guidance, start with the option that suits you best, explained below.
You can also watch our video.
1. Choose How You Want to Learn
TallyHelp gives you the flexibility to learn your way:
- Step-by-step instructions for guided learning
- Screenshots for better understanding
- Videos for quick visual learning
2. Find Help Instantly While You Are on TallyPrime
Need help on the go? On TallyPrime, simply press Ctrl+F1 from any screen.
The TallyHelp page opens context-sensitive help tailored to exactly what you’re doing on the screen.
3. Search for Content & Videos on TallyHelp
If you are on TallyHelp site, just enter the keyword based on the question you have. TallyHelp displays the most relevant help links and videos that you can refer to and find the required information.
4. Prefer to ask questions directly? Use TARA – The AI Help Chatbot
Ask your question as you want. Type your question, upload a TallyPrime screen image, record a video of the screens and upload, or even voice record your question – all directly within TARA and get instant responses to your query.
5. Explore Content End-to-End
Working across different Tally products?
Switch between products like TallyPrime and TallyPrime Server, and explore other tabs on the top menu.
Need help on different features in the product?
Within a product tab, navigate through the ToC on the left-navigation panel and open the required help page or video.
Want to explore more from within a page? On any help page, refer to the right-navigation panel and access other page link, along with the On this page section that includes the key sections on the page.
6. Quickly Resolve Common Queries
Refer to the FAQ pages to find answers to frequently asked questions—perfect for quick problem-solving.
7. Access Help Anytime, Even Offline
Download topics as PDFs and use them whenever needed—ideal for situations with limited or no internet access.
8. Keep TallyHelp Pages Within Reach
Bookmark the pages/URLs that you need to frequently refer to and access them from your laptop or mobile in a single click.
9. Build Expertise with Webinars
Access Tally webinars and join, as applicable to you, and learn directly from experts. Stay updated on new features and best practices.
Browse to the product download page, right from TallyHelp, to access the latest TallyPrime versions and upgrade.
