Set Up Party Ledger
Configure your party ledgers with the required VAT and e-Invoicing details to record transactions and generate compliant e-Invoices in the UAE. You can also update the TRN for multiple parties by importing the details.
Configure your party ledgers with the required VAT and e-Invoicing details in TallyPrime to generate compliant e-Invoices in the UAE.
Enable VAT & e-Invoicing.
Ensure that the required party ledger is created under Sundry Debtors or Sundry Creditors.
- Keep the party’s VAT registration and e-Invoicing details ready, as applicable.
In the Party ledger,
- Enter the party’s Mailing Details.
- Address: Enter the party’s address.
- Country: Select the party’s country.
- Emirate: Select the applicable emirate.
- Mailing details in local language: Set it to Yes if you want the mailing details to appear in Arabic on the invoice.
- Provide the party’s VAT Registration Details.
- Registration type: Select the applicable type.
- Regular: When the party is registered under UAE VAT and has a valid TRN.
- Unregistered: When the party is not registered under UAE VAT and does not have a TRN.
- Consumer: For retail or end customers where transactions are made directly with consumers instead of registered businesses.
- Date of VAT registration: Enter the date of VAT registration, as applicable.
- TRN: Enter the party’s Tax Registration Number.
- TIN: Automatically populates based on the first 10 digits of the TRN.
- Provide the party’s e-Invoice Details.
- Enable Provide e-Invoice details.
- Party registered on PEPPOL: Set it to Yes if the party is registered on the PEPPOL network, and enter the PEPPOL ID.
- Select the applicable Digital Location Number Issuer and enter the Digital Location Number.
If the party’s Registration Type is Unregistered, - Select the applicable Digital Identity Number Issuer and enter the Digital Identity Number, when applicable.
- Agency ID: Select the applicable Agency ID.
- Select the Legal Agency Identifier.
- Select the Agency Name.
- You can also press Ctrl+I (More Details) > e-Invoicing Registration Details to configure the e-Invoicing details.
- Provide the other required details and press Ctrl+A to save.
Questions & Answers
- What new information can I capture in the party ledger for e-Invoicing in UAE?
TallyPrime has introduced additional fields such as City, TIN, PEPPOL details, Digital Location and Digital Identity details, and Free Zone Number to support UAE e-Invoicing requirements. These fields are available once you enable e-Invoicing for the Company. -
What happens when I change the TRN or Registration Type of a party?
Transactions created on or after the effective date automatically use the updated TRN and Registration Type maintained in the party ledger history. -
I am upgrading to a new version in TallyPrime. Will my existing party ledger data be migrated?
Yes, the existing party ledger data is retained after migration. However, history records for the newly introduced e-Invoicing fields are not created automatically. History tracking begins when you first alter the ledger and save the changes with an effective date. -
Can I capture e-Invoicing details for multiple addresses?
When Enable multiple addresses is set to Yes in F11 (Company Features), you can capture e-Invoicing details separately for each address.
