Set Up Charge Ledger for UAE e-Invoicing
Charges such as freight, handling fees, insurance, or additional levies may need to be included in the taxable value of transactions for UAE e-Invoicing. By configuring a charge ledger with the appropriate statutory details, you can ensure accurate VAT calculation and compliant e-Invoice generation.
- Enable VAT & e-Invoicing.
In the Charge ledger,
- Under: Select one of the following parent groups:
- Direct Expenses
- Direct Incomes
- Indirect Expenses
- Indirect Incomes
- Duties & Taxes
- Current Assets
- Loans (Liability)
- Secured Loans
- Unsecured Loans
- Type of Ledger: Select Not Applicable.
- Provide the required Statutory Details.
- Taxability: Not Vatable.
- Include in Assessable Value Calculation: Select VAT, if the charge must be considered while calculating the taxable value.
- Appropriate to: From the List of Options, select the applicable transaction type.
- Method of Calculation: Select how the charge should be calculated for e-Invoicing.
- Based on Quantity: The charge depends on the quantity of goods supplied.
- Based on Value: The charge is calculated on the value of the supply.
- Reason for charge: From the List of Reasons, select the applicable reason.
- Provide other necessary details and press Ctrl+A to save.
