Set Up Excise Ledger for UAE e-Invoicing
Excise-related charges that form part of the transaction value must be reported correctly in UAE e-Invoicing. By configuring an excise ledger with the appropriate statutory details, you can ensure accurate tax treatment and compliant e-Invoice generation in TallyPrime.
In the Excise ledger,
  1. Under: Select one of the following parent groups:
    • Direct Expenses
    • Direct Incomes
    • Duties & Taxes
    • Indirect Incomes
    • Indirect Expenses
  2. Behave as Duties & Taxes ledger: Select Yes.
    If this option is not available, press F12 (Configure) > enable Set Ledgers to behave as Duties & Taxes.
  3. Select Others as the Type of Duty/Tax.
    excise-ledger
  4. Select Excise for Type of Ledger.
  5. Provide the required Statutory Details, if applicable.
    •  Select the applicable reason for Reason for charge.
  6. Provide other necessary details and press Ctrl+A to save.
