Inventory Vouchers in TallyPrime
Inventory vouchers in TallyPrime help businesses track stock movement and transfers, even with additional expenses such as transfer charges and storage. Additionally, you can update the physical stock available in case of any discrepancies identified in your inventory reports. This helps you reconcile available stock quantities in your books with the physical stock available at your site.
Stock Transfer Using Journal Voucher
With a Stock Journal voucher, you can:
  • Transfer goods between godowns or storage locations.
  • Track internal stock movement without affecting your books of accounts.
  • Update stock quantities at both source and destination locations.
  • Use Stock Journal vouchers for stock adjustments, shortages, and wastage entries.
With a Stock Journal voucher class, you can simplify stock transfer transactions in TallyPrime by automating inventory allocation and reducing manual data entry.
Additional Costs/Expenses Incurred in Transfer of Goods
You can account for additional expenses such as freight, transportation, loading, and handling charges during stock transfer. In TallyPrime, you can:
  • Evaluate inventory for accurate stock costing.
  • Record transfer expenses and maintain proper inventory value and profitability analysis.
  • Gain better visibility into overall operational and logistics costs.
Physical Stock Management
You can compare the actual stock available in your godown with the stock recorded in TallyPrime. This involves physically counting inventory items to identify shortages, damages, or excess stock. In case of any discrepancies in your inventory, you can record a Physical Stock voucher to reconcile differences between physical stock and book stock.
By doing so, you can ensure inventory accuracy and better reporting in audits, as your physical stock will be the same as the stock in your books.
Apart from that, you can also:
Apart from these inventory vouchers, TallyPrime also helps you track stock movement during your sales and purchase processes. You can record the delivery of goods with a delivery note and also account for the items returned by the buyer with a Rejections In voucher. Similarly, you can record the receipt of goods with a receipt note and account for the items returned to the supplier with a Rejections Out voucher.
