https://help.tallysolutions.com/docs/ts9rel54/ts9/business_process_optimisation.htm
Business Process Optimisation
Tally.Server 9 analyses system usage and user activities to optimise the various processes and time spent on them.
Since access is controlled through Tally.Server 9, authorised users will be able to monitor who is currently logged in, which companies are open, track the activities,  and even disconnect users if such a requirement arises. Each business process or function requires users to perform certain activities and spend some time to input and/or analyse information.
For Example , when a user has to take data from bank statement and use it as input for the bank ledger on the system, for reconciliation of balances.
A business may expect this function to take 60 man hours in a month, Tally.ERP 9 reports suggest that it is taking 120 hours. The business can then make corrective decisions to reduce the number of man hours spent.
Tally.Server 9 allows a user to discover such issues and work on them for necessary changes in the business function. The monitoring will help discover and optimise processes or system usage for enhanced productivity, which would otherwise be extremely difficult to analyse.
See also:
Concurrency
Security
Reliability
