HomeTallyPrimeAccountingTrack Additional Charges
Record Sales with Cost Centres to Track Additional Charges in TallyPrime
You can use cost centres to track additional charges in a sales invoice, such as transportation, packaging, and insurance.
For example, if you work with multiple transportation agents based on delivery areas, you can create a cost centre for each agent to track how much each one charges for transportation.
Ensure that:
  1. In F11 (Company Features), you have set Enable Cost Centre to Yes.
  2. You have created required additional charges ledger under Indirect Expenses.
  3. In the Ledger Creation/Alteration screen for additional charges ledger, press F12 (Configure) > set Apply Cost Centres for Ledgers to Yes.
In the Sales voucher:
  1. Enter the stock item details.
  2. Select the additional charges ledger, such as Transportation Charges.
  3. Enter the percentage under Rate. You can also enter the amount.
  4. In the Cost Centre Allocation screen, select the cost centre created for the respective transportation agent.
    Allocation of charges
    sales with additional charges
  5. Enter the necessary details, and press Ctrl+A to save the voucher.
