What’s New in KSA e-Invoicing Release 6.3
Multi-currency Support for Transactions
With TallyPrime, you can now record any transactions in foreign currency, except Advance Receipts. The PDF A3 format has also been enhanced to support:
- Multi-currency
- Buyer’s Order No.
- Date
- Remarks
- Exchange Rate
Display of Discount Amount in Invoices
You can now enable the option Use Discount Column in invoices in the F11 (Company Features) to display the discount amount during voucher entry.
Invoice Print Templates
Express your brand identity through your invoice:
- Get access to ready-to-use predefined bilingual templates.
- Explore simple and rich personalisation options: Add logos, watermarks (
), header/footer images (
), with custom fonts and colours to highlight key details, and include terms & conditions for clear communication (
). - Save and set your preferred template as default for each voucher type.
Resolved Duplication of e-Invoicing XML File
When you archived e-Invoices in the generation phase, the XML file of the first invoice was getting duplicated.
This issue is now resolved.
Support for KSA e-Invoicing Only in TallyPrime Edit Log
KSA e-Invoicing in TallyPrime will be discontinued from June 8th, 2026.
You can now use the latest TallyPrime Edit Log and load your existing data for a seamless e-Invoicing experience.
Update Voucher Status in e-Invoice Archive and e-Invoice Event Log
In the e-Invoice Archive and e-Invoice Event Log, you can now update the status of the vouchers as Pending for Archiving, Archive, or Tampered.
Secured Use of e-Invoice Overview Report
If the e-Invoicing plug-in is inactive, you will have limited access to the e-Invoice Overview Report.
Although you can view the data in the report for reference, the Update e-Invoice and Get Status options are disabled under the respective sections to avoid any misuse.
Enhanced Advance Receipt Details
You can now select stock items or service ledgers along with the Nature of Transaction in Advance Receipt, ensuring these details are accurately reflected in the PDF and printed output.
Comfortable Reading with Auto Wrap Text
No more compressing of long text.
Now view & share the details in your masters, transactions, and reports with perfect clarity, using Auto Wrap Text.
