View Memorandum Voucher Register in TallyPrime
The Memorandum Register in TallyPrime provides a month-wise view of all recorded memorandum vouchers. You can drill down to individual vouchers and record the actual transaction by changing the voucher type and entering the required amount.
- Press Alt+G (Go To) > type or select Memorandum Register > press Enter.
- Drill down from a particular month to view the list of Memorandum Vouchers.
- To view the Voucher Register in column-based format, press F8 (Columnar) and enable the options you want to view.
Alternatively, press Ctrl+H (Change View) and select Columnar. - To view the extract of all Memorandum vouchers, press Ctrl+H and select Extract.
- To view the list of cancelled vouchers and post-dated vouchers, press Ctrl+J (Exception Reports).
