Keyboard Shortcuts in TallyPrime
This topic lists the different shortcut keys that can be used in TallyPrime – for faster data entry.
.highlight { font-weight: bold; background-color: rgb(248, 233, 150); } #searchInput { border: 2px solid #CCE0F4; border-radius: 5px; font-size: 14px; width: 50%; } .searchContainerScroll { background-color: white; position: fixed; top: 70px; box-shadow: 0px 2px 5px rgba(0, 0, 0, 0.1); padding: 15px 15px 5px 15px; transition: top 1s; } .searchContainer { width: 100%; min-width: 300px; background-color: white; padding: 15px 15px 5px 0px; top: -10px; }
| Action | Shortcut in TallyPrime | Location in TallyPrime | Shortcut in Tally.ERP 9 |
To find the Help article from any screen in TallyPrime. |
Ctrl+F1 |
Any screen |
Alt+H |
| To open Notifications report | Ctrl+Alt+N | Top menu | NA |
| To go back to the previous screen by closing the currently open screen To remove inputs that is provided/selected for a field |
Esc | NA | Esc |
| To move to the first/last menu in a section | Ctrl+Up/Down | NA | Ctrl+Up/Down |
| To move to the left-most/right-most drop-down top menu | Ctrl+Left/Right | NA | None |
To move from any line to the first line in a list |
Home & PgUp |
NA |
Home & PgUp |
To from any point in a field to the beginning of the text in that field |
Home |
NA |
Home |
To move from any line to the last line in a list |
End & PgDn |
NA |
End & PgDn |
To move from any point in a field to the end of the text in that field |
End |
NA |
End |
To move one line up in a list To move to the previous field |
Up arrow |
NA |
Up arrow |
To move one line down in a list To move to the next field |
Down arrow |
NA |
Down arrow |
To move:
Left arrow | NA | Left arrow |
To move:
Right arrow | NA | Right arrow |
| To rewrite data | Ctrl+Alt+R | NA | Ctrl+Alt+R |
| To quit the application | Alt+F4 | NA | None |
| To view the build information | Ctrl+Alt+B | NA | Ctrl+Alt+B |
| To view TDL/Add-on details | Ctrl+Alt+T | NA | Ctrl+Alt+T |
| To accept or save a screen | Ctrl+A | NA | Ctrl+A |
| To expand or collapse a group in a table | Alt+Enter | NA | Alt+Enter |
| To move to the last field or last line | Ctrl+End | NA | Ctrl+End |
| To move to the first field or first line | Ctrl+Home | NA | Ctrl+Home |
| To open or hide calculator panel | Ctrl+N | NA | Ctrl+N (to Open) Ctrl+M (to Hide) |
| To hide or show the details in a table | Alt+T | NA | Alt+T |
| To open Company Features screen | F11 | Top menu | F11 |
| To primarily open a report, and create masters and vouchers in the flow of work. | Alt+G | Top menu | None |
| To switch to a different report, and create masters and vouchers in the flow of work. | Ctrl+G | Top menu | None |
| To open TallyHelp topic based on the context of the screen that is open | Ctrl+F1 | Top menu | Alt+H |
| To open the company menu with the list of actions related to managing your company | Alt+K | Top menu | None |
| To open the list of actions applicable to managing the company data | Alt+Y | Top menu | None |
| To open the list of actions applicable to sending or exchanging your company data | Alt+Z | Top menu | None |
| To open the import menu for importing masters, transaction, and bank statements | Alt+O | Top menu | None |
| To open the Share menu for sharing transactions or reports through e-mail or WhatsApp | Alt+M | Top menu | None |
| To open the print menu for printing transactions or reports. | Alt+P | Top menu | None |
| To open the export menu for exporting masters, transactions, or reports | Alt+E | Top menu | None |
| To select the display language that is applicable across all screens | Ctrl+K | Top menu | Alt+G |
| To select the data entry language that is applicable to all screens | Ctrl+W | Top menu | Alt+K |
| To export the current voucher or report | Ctrl+E | Top menu | Alt+E |
| To e-mail the current voucher or report | Ctrl+M | Top menu | Alt+M |
| To WhatsApp the current voucher or report | Ctrl+Alt+W | Top menu | Alt+M |
| To print the current voucher or report | Ctrl+P | Top menu | Alt+P |
| To open the Help menu | F1 | Top menu | None |
| To change the date of voucher entry or date/period for reports | F2 | Right button | F2 |
To change the date of voucher entry or period for reports To change the period of the company |
Alt+F2 | Right button | Alt+F2 |
| To switch to another company from the list of open companies | F3 | Right button | F3 |
| To select and open another company located in the same folder or other data paths | Alt+F3 | Right button | Alt+F3 |
| To shut the currently loaded companies | Ctrl+F3 | Right button | Alt+F1 |
| To open the list of configurations applicable for the report/view | F12 | Right button | F12 |
| To exit a screen or the application | Ctrl+Q | Bottom bar | Ctrl+Q |
| To activate find bar and initiate finding for user-entered information in masters and transactions | Alt+F | None |
Keyboard Shortcuts – Reports
| Actions | Shortcuts in TallyPrime | Location in TallyPrime | Shortcuts in Tally.ERP 9 |
| To insert a voucher in a report | Alt+I | Bottom bar | Alt+I |
| To create an entry in the report, by duplicating a voucher | Alt+2 | Bottom bar | Alt+2 |
| To delete an entry from a report | Alt+D | Bottom bar | Alt+D |
| To add a voucher in a report | Alt+A | Bottom bar | Alt+A |
| To cancel a voucher from a report | Alt+X | Bottom bar | Alt+X |
| To remove a line entry from a report | Ctrl+R | Bottom bar | Alt+R |
| To display all hidden line entries, if they were removed | Alt+U | Bottom bar | Ctrl+U |
| To display the last hidden line (If multiple lines were hidden, pressing this shortcut repeatedly will restore the last hidden line first and follow the sequence) | Ctrl+U | Bottom bar | Alt+U |
| To drill-down and open a voucher or master from the last level details of a report | Enter | Bottom bar | Enter |
| To drill-down and open a voucher for display | Ctrl+Enter | Bottom bar | Enter |
| To alter a master during voucher entry or from drill-down of a report | Ctrl+Enter | Bottom bar | Ctrl+Enter |
| To select/deselect a line in a report | Spacebar | Bottom bar | Space bar |
| To select or deselect a line in a report | Shift+Spacebar | Bottom bar | Shift+Spacebar |
| To continuously select/deselect multiple rows in a report | Shift+Spacebar+PgUp/PgDn | Bottom bar | Ctrl+Spacebar |
| To view the report in detailed or condensed format |
Alt+F1 |
| To open the GST Portal from GSTR-1 report | Alt+V | Right button | Ctrl+O |
To add a new column (except in Day Book and GST Returns) |
Alt+C | Right button | Alt+C |
To alter a column (except in Day Book and GST Returns) |
Alt+A | Right button | Alt+A |
To delete a column (except in Day Book and GST Returns) |
Alt+D | Right button | Alt+D |
To auto repeat columns (except in Day Book and GST Returns) |
Alt+N | Right button | Alt+N |
To filter data in a report, with a selected range of conditions
Right button | Alt+F12 |
After applying filter, to know the field where matches were found, press Filter Details
Right button | |
To calculate balances using vouchers that satisfy the selected conditions
Right button | Ctrl+F12 |
| To views values in different ways in a report | Ctrl+B | Right button | None |
| To change view – display report details in different views To navigate to different views of the report without changing the context |
Ctrl+H | Right button | F7/F8/F9 Alt+T |
| To view the exceptions related to a report | Ctrl+J | Right button | None |
| To expand or collapse information in a report | Shift+Enter | NA | Shift+Enter |
| To select or deselect lines till the end | Ctrl+Shift+End | NA | Ctrl+Shift+End |
| To select or deselect lines till the top | Ctrl+Shift+Home | NA | Ctrl+Shift+Home |
| To invert selection of line items in a report | Ctrl+Alt+I | NA | Ctrl+Alt+I |
| To perform linear selection/deselection multiple lines in a report | Shift+Up/Down | NA | None |
To navigate to the next artifact in the context To increment the Report date or next report in a sequence of reports displayed |
+ | NA | + |
To navigate to the previous artifact in the context To decrement Report date or previous report in a sequence of reports displayed |
– | NA | – |
To edit Profile |
Alt+I | Right button | NA |
To open Tally Portal from Profile |
Alt+V | Right button | NA |
Keyboard Shortcuts – Vouchers & Masters
| To delete a voucher | Alt+D | Bottom bar | Alt+D |
| To cancel a voucher | Alt+X | Bottom bar | Alt+X |
| To remove item/ledger line in a voucher | Ctrl+D | Bottom bar | Ctrl+D |
| To mark a voucher as Post-Dated | Ctrl+T | Right button | Ctrl+T |
| To autofill details in stat vouchers | Ctrl+F | Right button | Ctrl+A |
| To change mode – open vouchers in different modes | Ctrl+H | Right button | Ctrl+V (As Voucher mode) Alt+I (As Invoice mode) |
| To open the Stock Query report for the selected stock item | Alt+S | Right button | Alt+S |
| To mark a voucher as Optional | Ctrl+L | Right button | Ctrl+L |
| To add more details to a master or voucher for the current instance | Ctrl+I | Right button | None |
| To define stat adjustments during voucher entry | Alt+J | Right button | Alt+J |
| To view list of all vouchers or masters | F10 | Right button | None |
| To retrieve Narration for the same party from the previous voucher entry | Alt+R | NA | Alt+R |
| To open the calculator panel from Amount field during voucher entry | Alt+C | NA | Alt+C |
| To open a manufacturing journal from the Quantity field of a journal voucher | Alt+V | NA | Alt+V |
| To retrieve the Narration from the previous voucher, for the same voucher type | Ctrl+R | NA | Ctrl+R |
| To go to the next input field | Tab | NA | Tab |
| To go to the previous input field | Shift+Tab | NA | Shift+Tab |
| To remove the value typed | Backspace | NA | Backspace |
| To create another master on the fly while creating masters and vouchers | Alt+C | NA | Alt+C |
| To open the calculator panel | Alt+C | NA | Alt+C |
| To insert the base currency symbol in an input field. |
Alt+4 Ctrl+4 |
NA |
Ctrl+4 |
| To open the previously saved master or voucher To scroll up in reports |
Page Up | NA | Page Up |
| To open the next master or voucher To scroll down in reports |
Page Down | NA | Page Down |
| To copy text from an input field |
Ctrl+C Ctrl+Alt+C |
NA |
Ctrl+Alt+C |
| To paste input copied from a text field. |
Ctrl+V Ctrl+Alt+V |
NA |
Ctrl+Alt+V |
To create party using GSTIN/UIN, you can import GSTIN/UIN from Excel
Right button |
Keyboard Shortcuts for Currency Symbol
| Currency Symbol | Keyboard Shortcut – Laptop | Keyboard Shortcut – Desktop |
| UAE Dirham | Ctrl+Shift+6 | Ctrl+Shift+6 (Does not work with the grey keys on the extended keyboard) |
| Saudi Riyal | Ctrl+Shift+7 | Ctrl+Shift+7 (Does not work with the grey keys on the extended keyboard) |
| Indian ₹ | Ctrl+4 | Ctrl+4 |
| Pound Sterling £ | Copy and paste the symbol | Alt+0163 (Only works with the grey keys on the extended keyboard) |
| Euro € | Copy and paste the symbol | Alt+0128 (Only works with the grey keys on the extended keyboard) |
| Japanese Yen ¥ | Copy and paste the symbol | Alt+0165 (Only works with the grey keys on the extended keyboard) |
Keyboard Shortcuts to Open Vouchers
| To open Contra voucher | F4 | F10 > Accounting Vouchers | F4 |
| To open Payment voucher | F5 | F10 > Accounting Vouchers | F5 |
| To open Receipt voucher | F6 | F10 > Accounting Vouchers | F6 |
| To open Journal voucher | F7 | F10 > Accounting Vouchers | F7 |
| To open Stock Journal voucher | Alt+F7 | F10 > Inventory Vouchers | Alt+F7 |
| To open Physical Stock | Ctrl+F7 | F10 > Inventory Vouchers | Alt+F10 |
| To open Sales voucher | F8 | F10 > Accounting Vouchers | F8 |
| To open Delivery Note | Alt+F8 | F10 > Inventory Vouchers | Alt+F8 |
| To open Sales Order | Ctrl+F8 | F10 > Order Vouchers | None |
| To open Purchase voucher | F9 | F10 > Accounting Vouchers | F9 |
| To open Receipt Note | Alt+F9 | F10 > Inventory Vouchers | Alt+F9 |
| To open Purchase Order | Ctrl+F9 | F10 > Order Vouchers | None |
| To open Credit Note | Alt+F6 | F10 > Accounting Vouchers | Ctrl+F8 |
| To open Debit Note | Alt+F5 | F10 > Accounting Vouchers | Ctrl+F9 |
| To open Payroll voucher | Ctrl+F4 | F10 > Payroll Vouchers | None |
| To open Rejection In voucher | Ctrl+F6 | F10 > Inventory Vouchers | Ctrl+F6 |
| To open Rejection Out voucher | Ctrl+F5 | F10 > Inventory Vouchers | Alt+F6 |
Keyboard Shortcuts for e-Invoice
| Actions | Shortcuts | Location in TallyPrime |
| To send the transactions for e-Invoice generation from the Send for e-Invoicing screen | S | – |
| To export the transactions for offline e-Invoice generation from the Send for e-Invoicing screen | X | – |
| To cancel e-Invoice and voucher together while cancelling a voucher | I | – |
| To cancel e-Invoice and voucher together while deleting a voucher | I | – |
Keyboard Shortcuts for e-Way Bill
| To send the transactions for e-Way Bill generation from the Send for e-Way Bill screen | S | – |
| To export the transactions for offline e-Way Bill generation from the Send for e-Way Bill screen | X | – |
| To cancel e-Way Bill and voucher together while cancelling a voucher | I | – |
| To cancel e-Way Bill and voucher together while deleting a voucher | I | – |
Keyboard Shortcuts for Templates
The keyboard shortcuts for templates are applicable only to the Sales, POS, Sales Order, Delivery Note, Credit Note, and Debit Note vouchers.
| To change a template in the Voucher Printing screen | Ctrl+H | Right Button |
| To print a template without colour from the Voucher Printing screen | Alt+R | Right Button |
| To change the template to Tally Classic Format in the Voucher Printing screen | Alt+T | Right Button |
| To view the list of templates from the Invoice Templates screen | F2 | Right Button |
| To add/remove fields in the template from the Invoice Templates screen | F4 | Right Button |
| To include watermarks in the template from the Invoice Templates screen | F5 | Right Button |
| To include header image in the template from the Invoice Templates screen | F6 | Right Button |
| To include footer image in the template from the Invoice Templates screen | Alt+F6 | Right Button |
| To create or alter custom fields in the template from the Invoice Templates screen | F7 | Right Button |
| To update font & colour in the template from the Invoice Templates screen | F8 | Right Button |
| To update field properties in the template from the Invoice Templates screen | F9 | Right Button |
| To update print settings in the template from the Invoice Templates screen | F10 | Right Button |
| To save a template in the Invoice Templates screen | Ctrl+L | Right Button |
| To set a template as default from the Invoice Templates screen | Alt+L | Right Button |
| To copy the applicable configuration settings from Tally Classic format to a template | Alt+S | Right Button |
Keyboard Shortcuts for Plug-ins
| Feature | Actions | Shortcuts | Location in TallyPrime |
| KSA e-Invoicing | To see only those e-Invoices which are not yet archived from the e-Invoice Archives (Integration Phase) or e-Invoice Register (Generation Phase) | Alt+R | Right Button |
| To archive the e-Invoices from the e-Invoice Archives (Integration Phase) or e-Invoice Register (Generation Phase) | Alt+A | Right Button | |
| To save Return in the VAT Return report | Alt+B | Right Button | |
| To recompute changes in the VAT Return report | Alt+W | Right Button | |
| To save the changes as revised in the VAT Return report | Alt+H | Right Button | |
| To fetch the present e-Invoice status of a transaction from the B2C & B2B e-Invoices Overview report | Alt+U | Right Button | |
| To initiate e-Invoice reporting of a transaction from the B2C & B2B e-Invoices Overview report | Alt+T | Right Button | |
| To reinitiate e-Invoice reporting of a transaction from the B2C & B2B e-Invoices Overview report | Alt+R | Right Button | |
| To trigger and restart the e-Invoice reporting of a transaction from the B2C & B2B e-Invoices Overview report | Alt+N | Right Button | |
| To undo the vouchers that are marked as replaced under the Vouchers Marked as Replaced section of the B2C & B2B e-Invoices Overview report | Alt+A | Right Button |
