Record TDS on Expenses in TallyPrime
You can record TDS while accounting for business expenses. You can also record the expense first and deduct TDS later, or handle scenarios such as fixed assets, partial values, and cash payments separately.
Ensure that:
- You have enabled TDS in TallyPrime.
- You have created the required TDS masters.
In the Journal voucher:
- Debit the TDS expense ledger and enter the amount.
- Credit the TDS party ledger.
The amount after TDS deduction is calculated automatically. - Credit the TDS tax ledger.
The TDS amount is calculated automatically.
- Provide other necessary details, and press Ctrl+A to save the voucher.
Account for Expenses and Deduct TDS later
In some cases, you may account for an expense when you receive the bill and deduct TDS later. Record the expense first and then record the TDS deduction through a separate Journal voucher.
Account for the expense
- Debit the TDS expense ledger and and enter the amount.
- Credit the TDS party ledger and enter the amount.
Deduct TDS later
- Debit the TDS party ledger and enter the amount.
- Credit the TDS tax ledger and enter the amount.
- In the TDS Nature of Payment Details screen, enter the required details.
Record TDS on Fixed Assets
- Debit the TDS fixed asset ledger and enter the amount.
The amount is calculated automatically. - Credit the TDS tax ledger.
Deduct TDS on Partial Values
You can deduct TDS on only a part of the transaction value by modifying the assessable amount.
- Press F12 (Configure) > set Modify Tax details for TDS to Yes, and press Ctrl+A to save the configuration.
- Enter the TDS Nature of Payment Details.
Deduct TDS on Cash Payment for Expenses
You can record expenses paid through cash while deducting TDS from the party.
In the Purchase voucher:
- Select Cash as the Party A/c name.
- Under Party Details, in the Supplier (Bill from) field , select the party.
- Select the TDS expense and TDS tax ledgers.
- Verify the party details displayed for TDS deduction.
If you enter the party name manually in Party Details instead of selecting it from the list, specify the party’s PAN number and Deductee Type after selecting the TDS ledger.
Questions and Answers
Why is TDS not getting calculated on an expense?
Check the TDS applicability and Nature of Payment configured for the expense and party. Also verify the party’s PAN and deductee details. -
How can I check the TDS calculation for an expense transaction?
Open the transaction and press Ctrl+O (Related Reports) > TDS – Tax Analysis. Press Alt+F5 (Detailed) to view the tax breakup.
