HomeTallyPrimeIndia Compliance & TaxationIndia TDSTDS on Contractor Payments u/S 194C
Record TDS on Contractor Payments under Section 194C in TallyPrime
You can record TDS on payments to contractors for carrying out work, including supply of labour, under Section 194C.
Configure TDS Master (as per Section 194C)
For Section 194C, you can configure the Nature of Payment with the option to calculate tax if the purchase value exceeds Rs. 30,000 for a single bill or Rs. 1,00,000 in aggregate during the financial year.
In the the TDS Nature of Payment screen:
  1. Press F12 (Configure) and enable the option Allow single bill value.
  2. Select the Section as 194C.
    The Payment Code and Remittance Code will be filled automatically.
  3. Enter the single bill value and set the threshold limit.
    1. Set the Value limit for a single bill as 30,000.
    2. Enter the Threshold/exemption limit as 100,000.
  4. Select the rate as 1% With PAN and 20% Without PAN for individuals/HUF and other deductee types.
  5. Press Ctrl+A to save.
To learn how to configure other masters for TDS transactions, refer to the topic How to Create TDS Masters in TallyPrime.
Record TDS Purchase above the Single Bill Value limit
If the payment amount to a supplier crosses the single bill value limit of Rs. 30,000, TDS will be calculated as per Section 194C.
In the Purchase voucher:
  1. Once you have entered the Amount above 30,000, select the TDS tax ledger configured with the Nature of Payment as Payment to Contractors.
    As the payment has exceeded the single bill value limit of Rs.30,000, TDS will be calculated.
  2. Provide other necessary details, and press Ctrl+A to save the voucher.
As the single amount criteria are crossed in the voucher, in subsequent transactions, TDS will be deducted.
Similar to the purchase above the single bill value limit, if the purchase amount crosses the threshold limit of Rs. 100,000 set in the Nature of Payment for Section 194C, TDS will be calculated.
