HomeTallyPrimeIndia Compliance & TaxationIndia GST - RegularGST AdvancesOpening Balance for Unadjusted Advances Received
Provide Opening Balance for Unadjusted Advances Received Under GST
If you have advances received before the GST advance adjustment effective date that are still unadjusted, enter them as opening balances so you can adjust them in sales invoices.
If the sales invoice amount is less than the advance amount, the remaining balance continues to appear under unadjusted GST advances received for future adjustment.
  1. Press Alt+G (Go To) > GST Advances – Opening Balance > press Enter.
  2. Select Create Opening Balance (Advance Receipt).
  3. If you have created multiple GST registrations, select the applicable registration.
  4. Provide Party Name and Place of Supply.
  5. Enable the option Supply attracts Reverse Charge, if applicable.
  6. Provide details of unadjusted advances received before the applicable effective date.
    1. Date of GST Advances: Must be before the Applicable from date set while enabling advance adjustment in transactions.
    2. Taxability: Taxable.
    3. Enter GST Rate and Unadjusted Advance Amount, as applicable.
    4. Taxable Amount and tax values are calculated automatically.
      Opening Balance for Unadjusted Advances Received in TallyPrime
  7. You can add multiple advances in the same screen.
  8. Press Ctrl+A to save.
The opening balance appears as available for adjustment when you record sales invoices for this party.
Questions & Answers
  • What happens to the balance under unadjusted GST advances received if the sales invoice amount is less than the advance amount?
    If the sales invoice amount is less than the advance amount, the remaining advance balance continues to appear under unadjusted GST advances received. You can adjust the pending balance in the next sales invoice by selecting the same advance reference.
