HomeTallyPrimeInventoryJob CostingExpenses During Projects
Track Expenses Incurred During Projects in TallyPrime
In TallyPrime, you can track expenses incurred during projects or job work using either of the following methods:
Ensure that:
  • In F11 (Company Features), you have set Enable Job Costing and Enable Cost Tracking to Yes.
  • You have enabled cost allocation for stock items in the ledger.
    In the Accounting Ledger Creation/Alteration screen, set Allow cost allocation (stock item) to Yes.
    This option appears when Apply Cost Tracking of Stock Items for Ledgers is enabled under F12 (Configure).
  • You have created Cost Centres.
  • You have created ledgers, as applicable.
Accrue Expenses in Journal Voucher
  1. Press Alt+G (Go To) > Create Voucher and press F7 (Journal).
  2. Cost Centre/Classes: Select the applicable Cost Centre.
  3. Dr: Debit the expense or income ledger.
  4. Cr: Credit the payable account, say, the purchase ledger.
  5. In the Inventory Allocations and Stock Item Allocations screens, provide the necessary details.
    Accruing Expenses Using Journal Voucher
  6. Press Ctrl+A to save the voucher.
    The cost gets allocated to the specified Cost Centre.
Record Payments for Expenses
  1. Press Alt+G (Go To) > Create Voucher and press F5 (Payment).
  3. Select the bank/cash ledger and the expense ledger.
  4. Enter the Amount.
  5. Press Ctrl+A to save.
    The cost is allocated to the specified Cost Centre.
Questions & Answers
  • I want to distribute the expense across multiple Cost Centres. How can I do that?
    If an expense is applicable to more than one project, it can be allocated across multiple Cost Centres.
    While creating the voucher:
