https://help.tallysolutions.com/docs/te9rel61/Voucher_Entry/Inventory_Vouchers/Stock_Journal_Voucher.htm
Stock Journal Voucher
Stock journal is a journal in which all types of stock adjustments are entered.
The stock adjustment may be due to the following reasons:
     Inter-Godown Transfer: This is useful to transfer the goods from one location to another. The quantity of stock remains the same, but the location changes.
     Additional Cost/Expenses involved in the Transfer of goods: You can also account the additional cost incurred in connection of transfer of materials from one location to another.
     Accounting for Wastage of stock or shortage of stock: There may be a shortage or wastage of stock items, the quantity may have got changes. In such cases, you have to enter a stock journal to account for the increase or decrease in the Stock Item.
Manufacturing Process
If you are involved in the manufacturing process in which raw materials are consumed and finished goods are produced, then you can create a manufacturing Journal Voucher also.
To view the Stock Journal Voucher
1.    Go to Gateway of Tally > Inventory Vouchers.
2.    Click F7: Stk Jrnl.
For example, the company transfers Item B from the warehouse to the shop.
Note: To get the Godown details, enable the feature Maintain multiple Godowns in F11: Features > F2: Inventory Features.
Date
Enter the Date of Stock Journal entry.
Ref
Enter the reference number, if any, or leave it blank.
Note: To get the reference column in the Stock Journal, in F12: Configuration screen set Yes to Use Ref. Number in Stock Journal.
Following are the two parts of a stock journal voucher:
Source (Consumption)
Name of Item
Select the name of the Item from the List of Items, which needs to be transferred under Source.
Godown
Select the Godown from the List of Godowns, from which goods are getting transferred.
Note: The Godown address can be printed in a stock journal voucher.
Quantity, Rate, and Amount
Enter the quantity of the items that is getting transferred and rate. The amount will pop up automatically.
Note: The rate that is captured here is obtained from the Godown summary.
Destination (Production)
Name of Item
Select the name of the item from the List of Items under the column Destination.
Godown
Select the Godown from the List of Godowns, to which goods are being transferred.
Quantity, Rate and Amount
Enter the quantity of the items that is being transferred. The rate and amount will be displayed automatically.
Note: You can have a different Rate for Source (Consumption) and for Destination (Production) column for the same Stock Item.
When there are some Additional Cost/Expenses incurred, you can account the same in the Stock Journal.
After mentioning the quantity, rate and amount under Destination (Production), the Additional Cost Details screen will be displayed. Enter the additional cost/expense incurred.
Note: To get the additional cost details in the Stock Journal voucher, enable Track additional costs of purchases in F11: Features: F2: Inventory Features.
Narration
Enter the narration, if required.
To know more, click the links below:
     Creating a Manufacturing Journal Voucher
     Creating a Transfer Journal Voucher
     Creating a Consumption Journal Voucher
