https://help.tallysolutions.com/docs/te9rel61/Tax_India/Excise_Mfg/Excise_Registers.htm
Viewing Excise Registers (Excise for Manufacturer)
The excise registers can be viewed from Excise Registers menu.
To view the excise registers
  1. Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer.
  2. Click Excise Registers.
There are two registers available. Click on a register to know more.
Daily Stock Register
Rule 16 Register
