https://help.tallysolutions.com/docs/te9rel61/Advanced_Features/Advanced_Accounting_Features/Statement_of_Interest_Due_on_Invoices.htm
Statement of Interest Due on Invoices
You can calculate interest on each invoice for the period it is outstanding, wholly or partly. Transaction by transaction or bill-by-bill interest calculation is permitted for party accounts like accounts under the groups sundry debtors and sundry creditors. For interest calculation on each bill, Bill-wise details should be enabled for the company and the party.
To view the Ledger Interest report
1.    Go to Gateway of Tally > Display > Statements of Accounts > Interest Calculations > Ledger.
2.    Select the required ledger. The Ledger Interest report appears as shown below:
Note: The Cr in the interest amount indicates that it is a liability.
The interest liability and expense can be accounted by recording a journal entry. Interest can also be recorded using debit notes and credit notes with voucher class.
