https://help.tallysolutions.com/docs/te9rel61/Voucher_Entry/Advanced_Voucher_Entry/Adv_Voucher_Entry_in_Tally.htm
Introduction to Advanced Voucher Entry in Tally.ERP 9
Advanced usage in voucher entry involves using more features of Tally.ERP 9. This would mean entering of data in various pop-up and sub-screens depending on the context and configuration (both F12 and F11) settings.
Click the following links for more:
     Using Additional Cost of Purchase
     Using Tracking Numbers
     Using Zero Valued Entries
     Using different Actual and Billed Quantities
     Using Batchwise details
     Using Mfg. and expiry dates
     Using Cost Categories and Cost Centres
     Using Cost Centre Class
     Using Multi-currency
