https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/Odisha/OD_Dec_Output_Tax.htm
Recording Decrease in Output Tax (Odisha)
A journal voucher is recorded to adjust the decrease in output tax by selecting appropriate nature of adjustment and additional details
To create journal voucher for decreasing output tax in lieu TDS paid
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Decrease of Output Tax in the Nature of adjustment field.
o     Select the option TDS Adjustments in the Additional Details field.
o     Press Enter to save and return to voucher screen.
3.    Debit the VAT ledger created under the group Duties & Taxes.
o     Enter the Rate and Assessable Value in the VAT Details screen.
5.    Credit the ledger created under the group Current Assets. The journal voucher appears as shown below:
6.    Press Enter to save.
