https://help.tallysolutions.com/docs/te9rel61/Creating_Masters/Inventory_Info/Stock_Group.htm
Stock Group
Stock Groups in Inventory are similar to Groups in Accounting Masters. They are helpful in the classification of Stock Items.
You can group Stock Items under different Stock Groups to reflect their classification based on some common features such as brand name, product type, quality, and so on.
Grouping enables you to locate Stock Items easily and report their details in statements.
For example,
Stock Item
Sub Group
Main Group
Brand A - 19” TFT
Brand A
Grade One
Brand A - 17” CRT
Brand A
Grade One
Brand B - 19” TFT
Brand B
Grade Two
Brand B - 17” CRT
Brand B
Grade Two
You now have ready details of Grade One and Grade Two products, duly classified. You can also view the sub group classification.
     Go to Gateway of Tally > Inventory Info. > Stock Groups.
To know more, click the links below:
     Creating a Stock Group
     Creating Multiple Stock Groups
     Displaying a Stock Group
