https://help.tallysolutions.com/docs/te9rel61/Data_Management/Export_of_Data_Intro.htm
Exporting Data
Data can be exported from Tally.ERP 9 for many reasons such as for use in a third-party application, for filing returns, and so on.
You can export data in 6 different formats:
     ASCII (Comma delimited)
     Excel (Spreadsheet)
     HTML (web-publishing)
     JPEG (Image)
     PDF (Portable Document Format)
     XML (data interchange)
Click the following links for more information:
Export Formats
Exporting Masters
Exporting Vouchers
Exporting Reports
