How to Send Documents Using TallyPrime with WhatsApp
Starting TallyPrime Release 4.0, you can WhatsApp your business documents, such as your invoices and reports, directly from TallyPrime to your parties. Just sign up for WhatsApp, set up TallyPrime, and you are ready to send your documents to any WhatsApp number.
Know more...
Sign up for WhatsApp: To use this feature, you will need to add and register a valid contact number with WhatsApp Business Account (WABA). It involves signing up for TallyPrime with WhatsApp through our trusted business solution provider (BSP) – Interakt.
Interakt provides you the platform to
  • Connect TallyPrime with WABA for sharing documents.
  • Communicate with your customers and perform a host of other activities through your Interakt account.
Using the contact number registered with WABA, you can send instant messages, share documents, view response from your parties, and more – all through a secured and hassle-free environment. Contact your Tally Partner to sign up for WhatsApp and you will be all set. To know more, refer to Sign Up for WhatsApp & Onboard to Interakt.
Once you have completed your sign-up process, just add the registered number in TallyPrime, get access to the predefined templates from your Interakt account, and start sending documents to any WhatsApp number using the templates.
Share invoices and reports from TallyPrime: Record an invoice and send to one or more WhatsApp numbers. Drill down from your reports to open a voucher and instantly WhatsApp to your parties. If you wish to send a reminder letter for pending payments, simply open the outstandings report, drill down to the required entry to open the voucher, and share it from TallyPrime using a suitable template.
Secure use of TallyPrime with WhatsApp: If your business practices allow only certain user roles or users for sending documents to customers or parties, configure the user roles in TallyPrime to avoid unauthorised usage of the WhatsApp feature. You can restrict users from:
  • Directly sending invoices when recording
  • Sharing one or more reports or type of vouchers
  • Using one or more Business WhatsApp Number for sending documents
  • Adding or modifying WhatsApp numbers
TallyPrime with WhatsApp provides the flexibility to use the feature the way your business operates, with the added benefit of sending messages to parties from the secured Interakt platform.
Before you set up TallyPrime for WhatsApp, you must sign up for WhatsApp through Interakt. On completing the sign-up process, you will have your registered business number ready to be added to TallyPrime.
Add a Registered Business WhatsApp No.
You need to add your registered business WhatsApp number in TallyPrime to be able to share invoices and reports from TallyPrime. If you have not yet registered a contact number with your WhatsApp Business Account (WABA), refer to Sign up for WhatsApp and get onboarded to Interakt. When you add the number, you will need to log in for WhatsApp using your Interakt account credentials so that you are connected with the portal for sharing invoices and reports.
When you send the documents to your parties through the registered number, they will receive the communication with your business name, ensuring that it is authentic.
Before you add the registered business WhatsApp No. in TallyPrime, ensure the following:
  • Your subscription is active.
    1. Log in to the Interakt portal with your user credentials, click the Home icon
    2. Ensure that your subscription is active.
  • You have the default WhatsApp template, after completing the sign-up process on Interakt.
    1. On the left navigation pane on your Interakt account screen, click Templates.
    2. Ensure that the Utility sections list one or more templates approved by Meta.
Once you have confirmed, you can now add the Registered Business WhatsApp No. in TallyPrime.
  1. Press Alt+M (Share) > Manage > WhatsApp Nos.
    whatsapp-nos
    The Sign Up & Use Registered Business WhatsApp No. screen appears.
  2. Select the appropriate option to proceed.
    signup-and-register
    1. If you have not yet signed up for WhatsApp, press W (Sign Up & Subscribe). This will open the Customer Portal webpage where you can submit a sign-up request for WhatsApp for Business. Refer to Sign Up for WhatsApp & Onboard to Interakt for more information.
    2. If you have already signed up for WhatsApp and adding the number in TallyPrime for the first time, press A (Enter WhatsApp Details).
      The WhatsApp No. Details screen appears.
  3. Add the WhatsApp No. details.
    1. Enter the Registered Business WhatsApp No.
    2. Enter the Business Name and press Enter.
      Your Business Name can either be the name of your company in TallyPrime or the legal name of your business.
      A confirmation message appears on the screen, as shown below:
    3. Press Enter to confirm for log in.
      If you select No, the number gets added to your Company. However, you will need to log in prior to sending documents using this number,
      1. Press Alt+M (Share) > Manage WhatsApp No.
      2. Select the WhatsApp No. for which you want to log in, and press Enter.
  4. In the Login for WhatsApp screen, enter the Username and Password that you use to log in to your Interakt account, and press Enter.login-for-whatsapp
A successful login connects you with WABA through the Interakt portal. It also retrieves all the predefined WhatsApp templates from your Interakt account into TallyPrime. You can select and preview the templates while sharing documents through WhatsApp. To know more, refer to WhatsApp Templates.
You can add more than one number in TallyPrime and use a unique business name for each, once you have registered the numbers with WABA through your Interakt account.
Modify WhatsApp number details
Once you have added your WhatsApp number details in TallyPrime, you can start sharing invoices and reports to your desired parties. However, TallyPrime provides you with the flexibility to update your Business Name or WhatsApp number at any point in time.
If you wish to change your registered business WhatsApp number, you have to again register the number with Meta and add the number in TallyPrime. To know more, refer to the Interakt Account for WhatsApp section.
    The Select WhatsApp No. screen appears, as shown below:
    select-whatsapp-no
  2. Select the Registered Business WhatsApp No. that you wish to modify and press Enter.
    The WhatsApp No. Details screen appears as, shown below:
    modify-whatsapp-no-details
  3. Change the Business Name as per your requirement and press Ctrl+A to save.
WhatsApp templates
TallyPrime in WhatsApp comes with ready-to-use templates that will help you share your documents in a jiffy. To help you start sharing business documents at the earliest, without waiting for your designed templates to get approved by Meta, you will be provided with six predefined templates approved by Meta while adding your registered business WhatsApp number. Out of these twelve templates, six are meant for PDF files, while the other six are meant for JPEG images. These templates are designed to suit different business usages and you can use them to quickly share your documents from TallyPrime at the earliest. These templates are described in more detail in the following table. To know more, click here...
Templates Description
Party Template for Vouchers
This is a personalised template where the party’s name will be autofilled. When the document will be delivered to your party, the name of the party will appear in the message. This template contains other vital information like voucher no., voucher date, title of the attached document, and so on.voucher-whatsapp
Common Template for Vouchers
This is a common template for the vouchers where the ledger name may not be available. The template starts with a formal greeting applicable to any customer and contains other vital information like voucher no., voucher date, title of the attached document, and so on.
common-template-for-vouchers
Common Template for Reports
This is a template for sharing more than one document with one or multiple parties. This template can be used for all the reports available in TallyPrime, as it consists of a common message that is generic for all the reports.
common-template-for-reports
Common Template with Payment Link
This is a common template for the vouchers where you can attach a payment link along with the message, which will help your party to send payment instantly through the link. You can use this template for sharing a report with one or multiple parties. This template can be used for all the reports available in TallyPrime.
common-template-with-payment-link
Party Template with Payment Link
This is a personalized template where the party’s name will be autofilled. This template contains other vital information like voucher no., voucher date, title of the attached document, and so on. Through this template, you can attach a payment link along with the message to help your party pay instantly.
party-template-with-payment-link
Employee Template for Pay Slip
This is a personalised template where the employee’s name will be autofilled, along with the month.
employee-template
You can also customise your own set of templates as per your requirements and business needs. You can do so while sharing a document from TallyPrime, by selecting the Manage option, which will appear while selecting templates. You will be redirected to the Interakt portal, where you can design your own templates and share it with Meta for approval. Once your templates get approved, you can select the Refresh option while selecting the templates during the process of sharing document with the parties and the new templates will get updated in TallyPrime.
Only the templates approved by Meta will appear in the list of templates.
Send Documents from TallyPrime with WhatsApp
In your business, you might be sharing invoices or reports with your customers, parties, and others depending on the nature of transactions. For every sales, your buyer would need the sales invoice. For delivery of goods, the delivery person will need a delivery note. Similarly, you might want to remind your parties for the due payments, and so on. Now send documents directly from TallyPrime to your parties on their WhatsApp numbers.
Before you start sending documents from TallyPrime, ensure that you have completed the following:
In this section
Send documents from TallyPrime with WhatsApp
In TallyPrime Release 4.0, you can send documents, such as sales or purchase invoices, payment or receipts vouchers, order vouchers, Bills Outstanding, reminder letters, and so on to the WhatsApp numbers of your parties. As always, sending documents through WhatsApp is a simple process.
  1. Record a transaction (say Sales) or open any report (say Sales Register).
  2. Press Alt+M (Share), and select Current under WHATSAPP.
    whatsapp-current-invoice
    If you have not logged in for WhatsApp while adding the registered WhatsApp No. in TallyPrime, the Sign Up & Use Registered Business WhatsApp No. screen will appear.
  3. In the WhatsApp screen, specify the required details for sending the document.
    1. WhatsApp from: This is prefilled with your Registered Business WhatsApp No.
    2. WhatsApp to: Enter the WhatsApp No. of the recipient (the buyer).
      If you have set any default WhatsApp number in the party ledger, you can select the same in the WhatsApp to field.
      list-of-mobile-numbers
      To send the document to multiple mobile numbers at the same time
      1. Select Multiple Mobile Nos., select more than one number or add new numbers as needed.
      2. Select End of List once you have selected or added the numbers.
    3. Select the required File Format and WhatsApp template suitable for the document, and press Enter.
  4. Press C (Configure) to add any required information, such as Company Logo, GSTIN, and so on, to the invoice.
  5. Press P (Preview) to preview the template with the attached sales invoice and the message that will be sent to the recipient.
  6. Press W (WhatsApp) to send the invoice to the recipient’s WhatsApp number.
    voucher-whatsapp
    Whether your party is travelling, in a meeting, or at home, receiving the transaction details on WhatsApp in their phones makes it much more convenient for them to take immediate action.
As you saw, sending any document to your parties is now easy using TallyPrime with WhatsApp. Ensure that you select the correct WhatsApp template applicable for the document that you are sending, and you are set.
Lets consider the following scenarios and the templates applicable while sharing the documents.
Send an invoice with payment link
In the WhatsApp screen, under WhatsApp template, select Party Template with Payment Link.
whatsapp-party-template-with-payment-link
The party receives the invoice in their WhatsApp in no time. From the WhatsApp message, your party can tap the Pay Now button and make the payment right then.
Pay Slips to employees
If your company generates pay slips and shares them with employees, then TallyPrime with WhatsApp makes it extremely easy. Within a few seconds, you will be able to WhatsApp the pay slips of all your employees to their smartphones.
In the WhatsApp screen, under WhatsApp template, select Pay Slip Template for Employee, and press Enter.
employee-template-pay-slip
The employees will receive their respective pay slips in their WhatsApp in no time.
Reminder Letters for Bills Receivables
From TallyPrime, you can send Reminder Letters to your customers with the details of amounts outstanding against them, along with all details of the transactions and due dates. You can now send the Reminder Letters from TallyPrime with QR code and payment link, so that the customer can send you the pending amount at the earliest.
In the WhatsApp screen, under WhatsApp template, select Common Template for Reports, and press Enter.
Similarly, you can also share Confirmation of Accounts for Multi-Account Reports like All Ledger Accounts, One Ledger Accounts, and so on, with one or more parties by using the WhatsApp feature in TallyPrime.
As you saw, select the appropriate WhatsApp template, and share your documents with parties on their WhatsApp numbers. If you want more specific templates for sharing documents, you can create new templates from your Interakt account, get the templates approved by Meta, and use them from TallyPrime. To know more, refer to Create WhatsApp templates.
Send One or All Tiles of Dashboard
TallyPrime brings for you the flexibility of viewing your business information on a Dashboard for better analysis of data. View the summary of your financials, sales and purchase trends, and so on in the form of tiles, and share a single tile or all the tiles of your dashboard with stakeholders for their easy reference.
To know more about Dashboard and tiles, refer to the Dashboard in TallyPrime topic.
  1. Open the Dashboard report and press Alt+M (Share).
    1. To send the current tile, select WHATSAPP > Current.
    2. To send all the tiles, select WHATSAPP > All Tiles.
      dashboard-all-tiles
      If you have not logged in with your valid credentials from Interakt, then the Sign Up & Use Registered Business WhatsApp No. screen will first appear to help you with the sign-up process.
  2. Provide the required WhatsApp details, select the required file format and template, and press Enter.
  3. Configure or preview as needed and send documents through WhatsApp.
Sharing reports from TallyPrime to your parties’ WhatsApp is not limited to only certain invoices and reports. Depending on your business requirements, you can leverage this feature for any document in TallyPrime – like Balance Sheet, Profit and Loss A/c, Sales Register, Day Book, and so on.
Send vouchers through WhatsApp on saving
Depending on your transactions or parties, you might need to share your invoices immediately; for example, when a sale or payment is done. You only have to configure the respective voucher type in TallyPrime and you are all set.
For example, you want to share the sales invoice with your party immediately after recording it.
  1. Open the Voucher Type Alteration screen for Sales and configure.
    1. Press Alt+G (Go To) > Alter Master > Voucher Type > Sales.
    2. Press F12 (Configure) and set Allow sharing voucher through WhatsApp after saving to Yes.
  2. In the Voucher Type Alteration screen, set WhatsApp voucher after saving to Yes, and press Ctrl+A to save.
    vouchertype-alteration
  3. Record a sales invoice with the required transaction details, and press Ctrl+A.
    The WhatsApp screen appears.
  4. Update the WhatsApp numbers and other details and press W (WhatsApp) to send the invoice to the party.
Send documents to Party’s default WhatsApp No.
You might need to share your invoices with one or more parties frequently. Entering the WhatsApp number every time for one or more parties can be tedious and time-consuming. TallyPrime makes it simpler by allowing you to set the default WhatsApp number for your parties. Next time you want to send an invoice, selecting from the list of default WhatsApp numbers becomes so easy.
  1. Alter the party ledger and configure for default WhatsApp number.
    1. Press Alt+G (Go To) > Alter MasterLedger, and select the party ledger.
    2. Press F12 (Configure), and set Default WhatsApp No. to Yes.
      set-default-whatsapp-number-configuration
      If you want to specify more than one mobile number, you can set Provide multiple Mobile Nos. to Yes.
    3. Enter the Primary Mobile No.
      This number is automatically set as the Default WhatsApp No.
      If the party has multiple mobile numbers, you can select any other number as the Default WhatsApp No. Depending on your requirements, you can select more than one mobile number as the Default WhatsApp No.
      1. Under Default WhatsApp No., select Multiple Mobile Nos.
      2. In the Multiple Mobile Nos. screen, enter the Contact Name for each number, and press Ctrl+A to save.
        multiple-mobile-numbers
    4. As always, press Ctrl+A to save the party ledger.
  2. Record a sales invoice for the party, and press Ctrl+Alt+W to share.
  3. In the WhatsApp screen, select the default WhatsApp No. under the WhatsApp to field, and share the document.
    Ensure that the WhatsApp from, File Format, and WhatsApp templates fields are filled in with appropriate details.
You can also choose to set the Default WhatsApp No. to Not Applicable and enter the WhatsApp numbers of your parties manually whenever you want to send the documents through WhatsApp.
Update Contact Details on the Interakt Portal
You can send contact details of parties from the Ledger Contact Details report to register in the Interakt Portal, and the contact details will be updated in your Interakt account.
  1. In the Ledger Contact Details report, select the ledgers for which you want to send the Contact Names and Default WhatsApp No. to your Interakt account.
    Ensure that the the ledgers you select have the Default WhatsApp No. field updated. If not, press Alt+H (Multi Alter) to update and save.
  2. Press Alt+S (Send Contacts to Portal), select the Registered Business WhatsApp No. for which you need to send the contacts to the portal, and press Enter.
    The Exchange Summary appears, as shown below:
    exchange-summary-report-contactsTo know more, refer to the Exchange Summary section.
    Once you update the details and save this screen, the details get updated automatically in the respective party ledgers in TallyPrime. Isn’t that amazing?
Share documents with all your parties
Have you ever wondered if you can share a report for a particular ledger from Multi Account Reports? You can certainly do so and that too in just a few simple steps. If you want to share a Multi Account Report with all the associated parties, you can do so by updating the default WhatsApp numbers for all the party ledgers. To know more about updating the default WhatsApp numbers, refer to Send documents to Party’s default WhatsApp No. topic.
  1. Press Alt+M (Share) > Others under WHATSAPP > select Bills Receivable from Multi Account Reports.
    bills-receivable
  2. Select WhatsApp to and select All Ledgers.
  3. Select your required File Format and WhatsApp template, and press Enter.
  4. Configure and Preview, if needed, and press W (WhatsApp).
Since you are sending the report to more than one mobile number, a progress bar will appear to highlight the process of sharing documents one by one. It is followed by an Exchange Summary highlighting that the messages have been exchanged successfully.
To know more about Exchange Summary for failures, refer to the Exchange Summary section.
View Summary of WhatsApp Messages/Contacts Sent | Exchange Summary
  1. If you are sending messages to Multiple Mobile numbers, then an exchange summary appears highlighting that the messages have been exchanged successfully, as shown below:
If you are sending the document to a single number, the exchange summary does not appear.
While sending WhatsApp messages to parties, there might be a failure in sending the messages successfully due to different reasons. For example, the party’s mobile number might be incorrect or the WhatsApp Server might be down. In such situations, the Exchange Summary report displays the details of the failure along with the count of messages that were sent successfully.
exchange-summary-failure-report
Based on the reason for failure, you can resolve the issue and share the document again.
The Exchange Summary also appears when you try to update the contact details on Interakt. To know more, refer to the Update contact details in the Interakt portal section.
When you use WhatsApp to share your documents from TallyPrime, you also experience flexibility and speed as a user. To summarise, TallyPrime focuses on saving your time and energy and ensuring that you reach out to most of your parties within a fraction of second.
Set Up Security for WhatsApp in TallyPrime
In your business, you can set up security in TallyPrime for using the WhatsApp feature to avoid any unauthorised access. You can restrict User Roles from adding or modifying Business WhatsApp numbers, and accessing one or more reports.
You can also disallow one or more users from accessing the WhatsApp number added to your company.
In this section
Refer to our video:
Restrict a user from adding or modifying a WhatsApp No.
Your business practices and policies might require you to restrict access to the business WhatsApp number to only specific users in TallyPrime. Say, you want to allow only the admin to manage business WhatsApp numbers for the company. This helps in controlling unauthorized access to adding or modifying such numbers by other users. To meet the requirements, you can set the security feature in TallyPrime for users based on their user roles. Before starting the process, you have to ensure that security is enabled for your Company in TallyPrime.
  1. Press Alt+K (Company) and select User Roles under the User Management section.
    user-roles
  2. Select the security level from the List of Security Levels.
    data-entry-user-roles
  3. Set Allow to add/modify Registered WhatsApp No. to No.
    add-or-modify-registered-whatsapp-number
  4. Accept the screen.
Prevent a user from sharing vouchers before saving in TallyPrime
TallyPrime provides you with the flexibility to share vouchers before saving them. Moreover, you also have the option to prevent a certain user from doing so. The user will not be able to either export or share the specific voucher.
  3. Set Set/Alter rules for Print voucher before saving to Yes.
    set-alter-rules-for-print-vouchers-before-saving
Disallow a user from sharing one or more reports
You can restrict users from sharing certain reports in TallyPrime. For example, you can block a certain user from doing any kind of activity in Day Book, which includes Display, Print, Export, and Share through WhatsApp.
  3. Select Display/Print/Export/Share from Type of Access and press Enter.
    display-print-export-shareSelect Print/Export/Share from Type of Access and press Enter, if you wish to exclude the option of displaying the report.
  4. Select the particular report from the List of Reports.
  5. Accept the screen.
Disallow a user from using one or more WhatsApp number
If you have added multiple business WhatsApp numbers in the company, TallyPrime provides you with the flexibility to use them for sharing documents with your parties. However, if you want to manage the usage of these numbers to allow or disallow one or more of these numbers to only a specific user, you can do so by restricting a user from using one or more WhatsApp number for sharing.
  1. Press Alt+K (Company) and select Users and Passwords under the User Management section.
    Users for Company screen appears, as shown below:
    users-for-company
  2. Configure the registered WhatsApp numbers by pressing F12 (Configure) and setting Disallow Registered WhatsApp No. to Yes.
    disallow-registered-business-whatsapp-numbers
  3. Set Disallow Registered WhatsApp Nos. to Yes after filling in the details such as the Username, Password and so on, as per your requirement.
  4. Select the registered business WhatsApp numbers from the List of WhatsApp Nos. that you wish to restrict and select End of List.
    restrict-registered-whatsapp-nos
Now, the selected user cannot use the number or list of numbers to share documents through WhatsApp from TallyPrime.
Migrate your Interakt Account to Access WhatsApp in TallyPrime
Tally and Interakt have joined hands to help you share your business documents with parties from TallyPrime in a secure and seamless manner. However, to WhatsApp your documents from TallyPrime, you need to have an account on Interakt with your registered business WhatsApp number. To know more about how to create your account with Interakt, refer to the Set Up Your Interakt Account to Use WhatsApp in TallyPrime section.
But what if you already have an account with Interakt and it is not included in WhatsApp for Business in TallyPrime? In this case, you will be able to switch to Tally’s WhatsApp plan without any hassles.
What’s more? You will be able to retain your previous Wallet Balance after switching to WhatsApp for Business in TallyPrime.
If you are already onboarded with a different Business Solution Provider (BSP) other than Interakt, a few simple steps will help you migrate your account to Interakt. You can then go ahead and connect your business WhatsApp number to enjoy an easy way of sharing your business documents from TallyPrime.
Migrate to TallyPrime with WhatsApp from an existing Interakt account
Already have an account with Interakt, and wish to sign up for TallyPrime with WhatsApp? Contact your Tally Partner to get your sign up done for TallyPrime with WhatsApp. Interakt will help you to migrate from your existing Interakt account to a new account for TallyPrime with WhatsApp.
Discuss with your Tally Partner to understand the advantages and related consequences of moving to a new Interakt account.
  1. Create a new Interakt account for TallyPrime with WhatsApp.
  2. Raise a ticket with Tally Support with the help of your Tally Partner, by sharing the login e-mail IDs of the existing and new Interakt accounts.
Your Tally Partner will discuss with you to confirm and get the ticket forwarded to Interakt Support. Interakt will resolve the ticket by migrating your account details, including the Registered Business WhatsApp No. to the new Interakt account. You will receive a confirmation from Interakt once your new Interakt account has been updated. Contact your Tally Partner to activate your WhatsApp subscription.
If you had any wallet balance in your earlier Interakt account, the same will be carried forward to the wallet in the new account.
Migrate to TallyPrime with WhatsApp from a different BSP to Interakt
If you have already registered your contact number with a different Business Solution Provider (BSP) and wish to move the same contact number to Interakt for TallyPrime with WhatsApp, you can easily migrate the same. To know more, refer to the Migration from another BSP – Tally customers topic.
Helpful?
