e-Invoice Sandbox – FAQ
Get answers to all the frequently asked questions or FAQs regarding the e-Invoicing activities through the e-Invoice Sandbox system. This page covers answers to FAQs and possible solutions to the problems you may have faced during e-Invoice Sandbox registration on the Sandbox system or during e-Invoice trial through the e-Invoice Sandbox access in TallyPrime.
However, if you have questions on e-Invoicing on the live IRP, then you can find their answers on the e-Invoice – FAQ page.
Sandbox is an e-Invoice trial system through which you can get a firsthand experience of e-Invoicing activities before you go on to perform those activities on the live IRP.
No. Sandbox and live e-Invoice credentials are two different sets of credentials. Sandbox credentials are used for e-Invoice trial through the e-Invoice Sandbox system. On the other hand, live e-Invoice credentials that you must have generated on the Invoice Registration Portal (IRP) are used for e-Invoicing through on the live IRP.
No. You can experience e-Invoice trial through Sandbox by using only Sandbox credentials.
It is not recommended to use the live Company data for generating trial e-Invoices through the e-Invoice Sandbox system. We suggest you create dummy data that you can use for e-Invoicing activities through the e-Invoice Sandbox system.
It is recommended to use either dummy data or a copy of your live data to perform e-Invoice trial through the e-Invoice Sandbox system. However, if e-Invoice trial is performed on the live data, then you will need to cancel the e-Invoices generated through the e-Invoice Sandbox system in order to avoid any conflicts during e-Invoice generation on the live IRP.
The e-Invoice Sandbox registration is done on the e-Invoice Sandbox system. Click on the link to find the complete e-Invoice Sandbox registration procedure. You can also watch the video to know how to register on e-Invoice Sandbox.
Client ID that you need to enter during Sandbox registration with Tally as a GSP is as follows:
AACCT29GSPB5H8G
You can click Forgot Credentials? on the e-Invoice API Testing System login page to reset your password.
The error occurs when the e-Invoice Sandbox registration is already done for the GSTIN using Tally (India) Private Ltd as the GSP on the e-Invoice Sandbox system. You need to confirm with people in your organisation if the e-Invoice Sandbox credentials are already generated using the GSTIN.
You may get the Invalid Mobile No or Email ID error while registration as shown below.
Invalide Mobile No or Email ID error during e-Invoice Sandbox Registration
In such a case, ensure that you have registered the entered mobile number and email ID on the GST portal. If you have not registered the mobile number email ID, then you need to update the same on the portal.
If you have already updated the mobile number and email ID on the GST portal, then you need to raise a ticket on the portal by selecting the fields as shown in the image below.
Raising a Ticket on GST Portal after the Sandbox Registration is Failed due to Invalid Mobile No or Email
No. e-Invoice Sandbox is only meant for e-Invoice trial on a testing environment. Any e-Invoicing activity on the e-Invoice Sandbox system will not get updated on the live IRP.
No. e-Invoice Sandbox is only for e-Invoice trial on a testing environment. Any e-Invoicing activity on the Sandbox system will be neither updated nor published on the live GST portal.
No. The e-Invoice Sandbox system does not facilitate the uploading of JSON files for e-Invoice generation. You can only generate trial e-Invoices from TallyPrime by enabling e-Invoice Sandbox access at the company level.
Scenario: While carrying out any activity such as Upload or Export through e-Invoice Sandbox system, I get an error.
Possible Solution:
Check your internet connectivity.
Press F1 (Help) > About > and select Status of Online Access services.
If you are unable to access the status page, then you can check your Internet connection by restarting the router.
If you can access the status page, refer to the following:
Step 1: Check Proxy Configuration
You need to check if the proxy configuration is enabled.
  1. Press F1 (Help) > Settings > Connectivity > Show More > Proxy Server configuration.
    Proxy Server configuration under Settings in TallyPrime
  2. Set Use Proxy Server to No for both For Connection to Online Access Services and For Connection to Tally Gateway Server.
    Proxy Server Configuration screen in TallyPrime
  3. Press Ctrl+A to save to save the setting.
If the issue persists, refer to the following section.
Step 2: Check Antivirus/ Firewall settings
You need to add TallyPrime Program Files to Exception List of Windows Firewall.
If the issue still persists, refer to the following section.
Step 3:
The host name should be whitelisted in order to use e-Invoice trial through the e-Invoice Sandbox system.
To know how to do it, refer to the topic Exclude IP/Hostnames in Firewall or Proxy.
The following table shows the prerequisites for e-Invoicing activities through e-Invoice Sandbox system.
License Status Online e-Invoicing Offline Export JSON Upload on e-Invoice Sandbox after Offline Export
License with TSS Works Works Not supported on e-Invoice Sandbox
License without TSS Works Works Not supported on e-Invoice Sandbox
Educational Mode Works Works Not supported on e-Invoice Sandbox
The Sandbox environment provided by NIC is for demonstration or practice purpose and is not near to real/live systems. Although valid GSTINs are not expected to be rejected in Sandbox, the database of GSTINs on Sandbox is not real time and scenarios of rejection are likely. For Sandbox demo, you can try with some of the sample GSTINs given below:
  • 33AACCT3705E005
  • 05AAACE8354Q1Z6
  • 05AAACE6641E2Z0
  • 23AABCS9608N2ZZ
The NIC has provided the Sandbox portal only for trial or practice, and the GSTIN database might not be fully updated at all times. Therefore, a few GSTINs might be rejected even when they are perfectly valid.
If you are facing such an issue, you can still experience a Sandbox demo by using some of the following sample GSTINs:
  • 33AACCT3705E005
  • 05AAACE8354Q1Z6
  • 05AAACE6641E2Z0
  • 23AABCS9608N2ZZ
{ "@context": "https://schema.org", "@type": "FAQPage", "mainEntity": [{ "@type": "Question", "name": "What is Sandbox?", "acceptedAnswer": { "@type": "Answer", "text": "Sandbox is an e-Invoice trial system through which you can get a firsthand experience of e-Invoicing activities before you go on to perform those activities on the live IRP." } },{ "@type": "Question", "name": "Are Sandbox and live e-Invoice credentials same?", "acceptedAnswer": { "@type": "Answer", "text": "No. Sandbox and live e-Invoice credentials are two different sets of credentials. Sandbox credentials are used for e-Invoice trial through the e-Invoice Sandbox system. On the other hand, live e-Invoice credentials that you must have generated on the Invoice Registration Portal (IRP) are used for e-Invoicing through on the live IRP." } },{ "@type": "Question", "name": "Can production login credentials be used for e-Invoice trial through the e-Invoice Sandbox system?", "acceptedAnswer": { "@type": "Answer", "text": "No. You can experience e-Invoice trial through Sandbox by using only Sandbox credentials." } },{ "@type": "Question", "name": "Can the live Company data be used for e-Invoice trial through the e-Invoice Sandbox system?", "acceptedAnswer": { "@type": "Answer", "text": "It is not recommended to use the live Company data for generating trial e-Invoices through the e-Invoice Sandbox system. We suggest you create dummy data that you can use for e-Invoicing activities through the e-Invoice Sandbox system." } },{ "@type": "Question", "name": "What are the consequences of using the live Company data for performing the e-Invoice trial activities through the e-Invoice Sandbox system?", "acceptedAnswer": { "@type": "Answer", "text": "It is recommended to use either dummy data or a copy of your live data to perform e-Invoice trial through the e-Invoice Sandbox system. However, if e-Invoice trial is performed on the live data, then you will need to cancel the e-Invoices generated through the e-Invoice Sandbox system in order to avoid any conflicts during e-Invoice generation on the live IRP." } },{ "@type": "Question", "name": "How do I register on e-Invoice Sandbox?", "acceptedAnswer": { "@type": "Answer", "text": "The e-Invoice Sandbox registration is done on the e-Invoice Sandbox system." } },{ "@type": "Question", "name": "What is the Client ID that needs to be entered during e-Invoice Sandbox registration with Tally as a GSP?", "acceptedAnswer": { "@type": "Answer", "text": "Client ID that you need to enter during Sandbox registration with Tally as a GSP is as follows: AACCT29GSPB5H8G" } },{ "@type": "Question", "name": "I have forgotten my e-Invoice Sandbox login password. How can I change or reset it?", "acceptedAnswer": { "@type": "Answer", "text": "You can click Forgot Credentials? on the e-Invoice API Testing System login page to reset your password." } },{ "@type": "Question", "name": "I am getting error as client id is already linked to GSTIN during Sandbox registration. How do I move forward from here?", "acceptedAnswer": { "@type": "Answer", "text": "The error occurs when the e-Invoice Sandbox registration is already done for the GSTIN using Tally (India) Private Ltd as the GSP on the e-Invoice Sandbox system. You need to confirm with people in your organisation if the e-Invoice Sandbox credentials are already generated using the GSTIN." } },{ "@type": "Question", "name": "I am getting an error, Invalid Mobile No or Email ID... Please click Button to update from CP during the e-Invoice Sandbox registration. How do I move forward from here?", "acceptedAnswer": { "@type": "Answer", "text": "In such a case, ensure that you have registered the entered mobile number and email ID on the GST portal. If you have not registered the mobile number email ID, then you need to update the same on the portal." } },{ "@type": "Question", "name": "Will the e-invoices generated on Sandbox be moved to live e-Invoice/NIC environment?", "acceptedAnswer": { "@type": "Answer", "text": "No. e-Invoice Sandbox is only meant for e-Invoice trial on a testing environment. Any e-Invoicing activity on the e-Invoice Sandbox system will not get updated on the live IRP." } },{ "@type": "Question", "name": "Will the e-Invoices generated on Sandbox get updated on the GST portal?", "acceptedAnswer": { "@type": "Answer", "text": "No. e-Invoice Sandbox is only for e-Invoice trial on a testing environment. Any e-Invoicing activity on the Sandbox system will be neither updated nor published on the live GST portal." } },{ "@type": "Question", "name": "Can I generate e-Invoice by uploading the JSON on the e-Invoice Sandbox system?", "acceptedAnswer": { "@type": "Answer", "text": "No. The e-Invoice Sandbox system does not facilitate the uploading of JSON files for e-Invoice generation. You can only generate trial e-Invoices from TallyPrime by enabling e-Invoice Sandbox access at the company level." } },{ "@type": "Question", "name": "I am unable to carry out e-Invoicing activities such as Upload or Export.", "acceptedAnswer": { "@type": "Answer", "text": "Scenario: While carrying out any activity such as upload or Export through e-Invoice Sandbox system, I get the following error: Possible Solution: Check your internet connectivity. Press F1 (Help) > About > and select Status of Online Access services. If you are unable to access the status page, then you can check your Internet connection by restarting the router. If you can access the status page, refer to the following: Step 1: Check Proxy Configuration You need to check if the proxy configuration is enabled. Press F1 (Help) > Settings > Connectivity >Show More > Proxy Server configuration. Set Use Proxy Server to No for both - For Connection to Online Access Services and For Connection to Tally Gateway Server. Press Ctrl+A to save to save the setting. If the issue persists, refer to the following section. Step 2: Check Antivirus/ Firewall settings You need to add TallyPrime Program Files to Exception List of Windows Firewall. For Windows 7: Add TallyPrime Program Files to Exception List of Windows 7 Firewall For windows 8: Add TallyPrime Program Files to Exception List of Windows 8 Firewall For windows 10: Add TallyPrime Program Files to Exception List of Windows 10 Firewall If the issue still persists, refer to the following section. Step 3: The host name should be whitelisted in order to use e-Invoice trial through the e-Invoice Sandbox system. To know how to do it, refer to the topic Exclude IP/Hostnames in Firewall or Proxy." } }] }
