Set Up Company Features in TallyPrime
As you create a company in TallyPrime, you can set up the necessary features, either now or anytime later, based on your business needs. The basic minimum key features required for you to start recording your business transactions are enabled and displayed by default.
  1. Set company features, such as Accounting, Inventory, Taxation, Payroll and so on.
    • Created company for the first time: The Company Features screen appears as the next step.
    • Created the company without setting up the features, press Alt+K (Company) > F11 (Features).
  2. To view all the options that you can set:
    • Set the Show more features option to Yes.
    • Set the Show all features option to Yes.
  3. Set up the feature as per your business needs. Refer to the following table for a description of each feature applicable for the company.
Features Description
Accounting
Maintain Accounts This option is set to Yes, by default. Setting it to No will disable accounting-related options for your company.
Enable Bill-wise entry
Enable this option to display the option Maintain balances bill-by-bill created under sundry debtors and creditors.
When you enter details of sales and purchases with the bill-wise option activated, TallyPrime prompts you to identify the invoice with an appropriate reference number.
The reference number can then be used to allocate payments to the correct invoice to maintain an accurate account of outstanding.
Bill-wise details for non-trading accounts are useful when one needs to track either an installment to be paid or a loan amount to be received over a certain period.
Enable Cost Centres
Set Show more features to Yes to view this option.
Used for maintaining and allocating expenses to cost centres.
Enable Interest Calculation
Enable this option to calculate interest automatically based on the interest rate and the style of calculation specified.
This is useful when interest rates change from time to time.
Inventory
Maintain Inventory
This option is set to Yes by default. This allows you to maintain your stock or inventory. Setting this to No will disable Inventory-related features for your company.
Integrate Accounts with Inventory
Set Show more features to Yes.
Maintain your stock or inventory along with your books of accounts.
Stock records may contain errors caused by wrong allocation to items. This feature enables finalization of financial books without waiting for the reconciliation of stocks.
You can drill down from the Balance Sheet to view the Stock Register.
Enable multiple Price Levels
Create multiple price levels for your stock items.
Enable Batches
Maintain batch information pertaining to Stock Items. Setting this option to Yes displays the Maintain in Batches field in the Stock Item Creation screen.
Maintain Expiry Date for Batches
Set expiry dates for the batches. This displays the Use Expiry Dates field in the Stock Item Creation screen.
Enable Job Order Processing
Set Show all features to Yes.
Create Job Work Out or Job Work In orders.
Enable Cost Tracking
Analyse and track the cost of an item in transactions.
Use Discount column in invoices
Use separate Actual and Billed Quantity columns in invoices
Specify quantities that are different from those delivered/received when invoicing.
Taxation
Enable Goods and Services Tax (GST)
If your business is under the GST regime, set this option to Yes and specify the GST Details for your company.
Set/Alter GST Rate and Other Details
For TallyPrime 3.0 & later, set up GST rates, HSN/SAC details.
If you have multiple GST registrations, use the multi-GSTIN feature to create your registrations under the same company name.
Set up all taxation-related options, such as e-Invoice and e-Way Bill, Reconciliation, MSME and so on.
Enable Tax Deducted at Source (TDS)
If your business considers TDS payments, set this option to Yes and specify the TDS deductor details along with the applicable Rates and Exemptions.
Enable Tax Collected at Source (TCS)
If your business considers TCS payments, set this option to Yes and specify the TCS collector details along with the applicable Rates and Exemptions.
Enable Value Added Tax (VAT)
If your business is under the VAT regime, set this option to Yes and specify the VAT Details for your company.
Enable Excise
Allow considering excise-related details during voucher entry.
Enable Service Tax
If you pay service tax as part of your business transaction, set this option to Yes and specify the service tax details and set the preferences for your company.
Online Access
Enable Browser Access for Reports
Once your company is connected to Tally.NET server, access the key business report from the broswer in any device using your Tally.NET credentials.
Enable Tally.NET Services for Remote Access & Synchronisation
Use features like Remote Access and Synchronisation.
Payroll
Maintain Payroll
Maintain payroll information in TallyPrime for the selected company.
Enable Payroll Statutory
Maintain payroll-related statutory information.
Others
Enable multiple addresses
Add multiple addresses for your company, as per your business needs.
Mark modified vouchers
For audit purposes, view all vouchers that are altered after creation.
Once the company and necessary features are set, you can now configure additional options for your company, if needed.
