HomeDeveloper ReferenceDeveloper PortalDeveloper Portal Help Guide
Developer Portal is your central workspace to publish, manage, and grow your solutions on Tally Marketplace.
This guide brings together everything you need, from getting started to scaling your solutions, with easy access to detailed help resources for each step.
Set up your access to the Tally Developer Portal and find your way around. This includes logging in with your Tally.NET ID, getting developer access approved, and exploring your dashboard.
  • Log in with your Tally.NET ID and select your account
  • Request developer access through the interest form
  • Explore your dashboard, resources and support tools
Publish Your Solution
List your solution on the Marketplace by adding all the required details and assets. This includes building & uploading your TCP file, adding descriptions, and configuring pricing or evaluation options.
  • Create and configure your solution listing
  • Upload TCP and supporting assets
  • Set accurate pricing and evaluation
Manage Your Listings
Keep your solutions up to date after publishing. You can edit details, release new versions, and control the visibility of your listings at any time.
  • Edit listing details
  • Manage updates and new versions
  • Manage listing status and availability
Customer Support
Handle customer queries directly through Developer Hub. Quick and effective response helps in building trust and improves the overall user experience.
  • View and manage customer queries
  • Respond to support tickets
  • Ensure timely resolution of queries
Performance & Insights
Track how your solutions are performing on the Marketplace using built-in insights.
  • View downloads and sales performance
  • View Revenue Generated
  • View Total vs Live solutions
Note: This section will active once Tally Marketplace is live.
Best Practices
Follow recommended guidelines to ensure your solutions perform well and deliver a great user experience on the Marketplace.
FAQs & Support
Find answers to common questions or reach out for additional assistance whenever needed.
Existing TallyShop Partner?
Your solutions will be migrated automatically from TallyShop to Developer Portal. To understand more, read the docs attached.
