HomeTallyPrimeGCC Compliance & TaxationKSA VATAdjust Advance Received in Sales
Adjust Advance Received in Sales Invoice in TallyPrime (KSA)
If you have received an advance from a customer and generated an e-Invoice for it, you can adjust the advance against the final sales invoice.
This helps accurately account for the advance amount while generating the sales e-Invoice.
In a sales voucher (Item Invoice mode):
  1. Set Show e-Invoice details: Yes and specify the Integration or Generation phase e-Invoice details in the e-Invoice Details screen, as needed.
  2. Enter the reference of advance received in the Bill-wise Details screen.
    bill-wise-details-for-sales-invoice
  3. Press Ctrl+A to save the voucher.
  4. Press Y or select Yes to generate the e-Invoice.
    e-invoice-confirmation-message
After generating the e-invoice, you can check the PDF A3 format file embedded with XML in the archived location of e-Invoices.
Print Preview of Sales Invoice in Which Advance Receipt Amount is Adjusted TallyPrime
