{ "@context": "https://schema.org", "@type": "FAQPage", "mainEntity": [{ "@type": "Question", "name": "Is the new TDS Nature of Payment for Section 194N provided in TallyPrime?", "acceptedAnswer": { "@type": "Answer", "text": "Yes, this new TDS Nature of Payment is available in the list of Nature of Payment (wherever applicable)." } },{ "@type": "Question", "name": "Is the calculation of TDS Section 194N supported in TallyPrime?", "acceptedAnswer": { "@type": "Answer", "text": "Only the TDS category name – Payment of certain amounts in cash – is provided in the Nature of Payment list. The calculation is not supported. As per Finance Bill No. 2, this TDS nature of payment is applicable for financial institutions. The department has notified that if a person makes cash withdrawals from financial institutions in excess of the threshold limit of. 1 crore, the financial institution must deduct TDS on the difference amount before making the payment. We are working to support TDS calculation as per this requirement, and a resolution will be available in our upcoming release." } },{ "@type": "Question", "name": "In the 'Uncertain Resolution' screen of 'PAN not available for party', I have selected the 'PAN Status' as 'Not Applicable'. The voucher is still appearing under 'Uncertain Transactions'. How to resolve this exception?", "acceptedAnswer": { "@type": "Answer", "text": "In the PAN not available for party screen of Form 26Q – Uncertain Resolution, keep the cursor on PAN No. field. Enter one of the terms given below, based on the corresponding reason: PANAPPLIED – If the party has given a declaration stating that he/she has applied for PAN but are yet to receive the same. PANINVALID – If the PAN format provided by the party is incorrect. PANNOTAVBL – If the party has not given any declaration or PAN number. The cursor will skip the PAN Status column. Once you save this screen, the voucher will be included in the return." } },{ "@type": "Question", "name": "An error Partially overlapped appears while saving TDS Stat payment. Why?", "acceptedAnswer": { "@type": "Answer", "text": "Consider the following example, in which the error Partially overlapped can occur. A Stat Payment already exists (made on 12-Dec-2018) for a particular period (1-Nov-2018 to 30-Jan-2019). If another stat payment is recorded (on 12-Jan-2019) for an overlapping period (1-Jan-2019 to 31-Jan-2019), the error Partially overlapped occurs while saving the voucher. To correct this: Gateway of Tally > Display More Reports > Statutory Reports > TDS Reports > Challan Reconciliation. Alternatively, Alt+G (Go to) > type or search Challan Reconciliation > Press Enter. View the TDS Challan Reconciliation report for any date on which the payment entry was recorded (12-Dec-2018, in this example). Click L: Show All and correct the To period for the voucher (as 30-Nov-2018, in this example), and save it. Now you can record a new Stat Payment voucher." } },{ "@type": "Question", "name": "Challan and deductee details are not captured in e-TDS file. Why?", "acceptedAnswer": { "@type": "Answer", "text": "When the stat payment transaction recorded to remit the TDS amount to the department is not reconciled with the challan details, the information of deductees from whom TDS was deducted, was not captured in the e-TDS return file generated for Form 26Q and Form 24Q. You need to reconcile the TDS payment transaction and record challan details to get deductee information in the e-TDS file. Go to Gateway of Tally > Display> Statutory Reports> TDS Reports > Challan Reconciliation. Alternatively, Alt+G (Go to) > type or search Challan Reconciliation > Press Enter. Select the required payment transaction in the Tax Reconciliation Report screen. Press Alt+R (Reconcile) to reconcile. Enter the From and to date of the quarter, Cheque/DD No., Cheque/DD Date, BSR Code of the bank, Challan No. and Challan Date. Press Ctrl+A to accept. After challan reconciliation, go to Form 26Q report, re-compute and overwrite the returns, before generating the e-TDS file." } }] }
