Data Captured in GSTR-1 e-Return
GSTR-1 return can be exported in the e-return format for any given period. All the transactions that are displayed under Included in returns section in GSTR-1 report will be exported.
All the necessary values can be exported to the return in the Excel and JSON formats. If you have exported in the Excel format, the file can be imported to the offline utility tool. This tool then creates the JSON file that can be uploaded on the GST portal. Refer to File GSTR-1 for the complete procedure.
The Receiver Name is not mandatory for filing. Hence, this column is not exported to the Excel sheet.
The description of the sheet and columns in the exported Excel sheet is given below:
Worksheet and column names
Description
b2b
Displays the details of 1 B2B invoices – 4A, 4B, 4C, 6B, 6C table of GSTR-1 report.
Taxable sales made to regular and composite dealers are captured here. If your tax invoice had exempt and nil rated items along with taxable items, then the total invoice value is captured here.
If you want to capture the values of only the taxable items as a B2B invoice, as per GST rules record separate invoices for taxable items. Use separate invoices (bill of supply) for sales of exempt/nil rated items.
Displays the value of sales recorded with:
Nature of transaction as:
  • Sales Taxable
  • Interstate Sales Taxable
  • Sales Exempt
  • Interstate Sales Exempt
  • Sales Nil Rated
  • Interstate Sales Nil Rated
  • Sales to SEZ – Exempt
  • Sales to SEZ – LUT/Bond
  • Sales to SEZ – Taxable
  • Deemed Exports Exempt
  • Deemed Exports Taxable
  • Deemed Exports Nil Rated
  • Intrastate Deemed Exports Taxable
  • Intrastate Deemed Exports Exempt
  • Intrastate Deemed Exports Nil Rated
Taxability as
  • Taxable
  • Exempt
  • Nil Rated
Registration type as
  • Regular
  • Composite
GSTIN/UIN of Recipient
Displays the following:
  • The GSTIN/UIN predefined for party ledgers, or entered in the Party Details screen of the voucher.
  • The GSTIN/UIN entered for the buyer in the Buyer’s Details section of the Party Details screen when consignee and buyer details are provided.
  • The GSTIN/UIN entered in the Party Details screen of receipt voucher, when a sales transaction is recorded in receipt voucher.
Invoice Number
Displays the voucher number of the outward supply transactions.
Special characters other than “-” and “/” in the voucher number are not exported.
If the length of the voucher number is more than 16 characters, including the special characters, offline tool will display a validation error.
Invoice date
Displays the voucher date of the sales transaction.
Invoice Value
Displays the total value of the voucher including tax and cess.
Place Of Supply
Displays the State Name and state Code based on the Place of Supply of the buyer in the Party Details screen of the voucher.
Reverse Charge
Displays Y if it is a reverse charge transaction, else N.
Applicable % of Tax Rate
This column is currently left blank.
Invoice Type
Displays Regular for vouchers recorded with the following Nature of transaction:
  • Sales Taxable
  • Sales Exempt
  • Sales Nil Rated
Displays SEZ supplies with payment for vouchers recorded with Sales to SEZ – Taxable as the nature of transaction.
Displays SEZ supplies without payment for vouchers recorded with the following Nature of transaction:
Displays Deemed Exp for vouchers recorded with the following natures of transactions:
E-Commerce GSTIN
Displays the GSTIN/UIN of the e-commerce operator party selected in the voucher.
Displays the GSTIN/UIN of the buyer selected in the Party Details screen of the voucher, in the GSTIN/UIN of Recipient column of this worksheet.
Note: The GSTIN/UIN of the e-commerce operator party selected in the voucher, and the GSTIN/UIN entered in Party Details screen of the voucher should be different.
Rate
Displays the integrated tax rate with decimal places.
If the stock item is nil rated or exempt, the tax rate appears as 0.00.
Taxable Value
Displays the assessable value entered for each tax rate.
Cess Amount
Displays the cess amount of the voucher.
b2cl
Displays the details of table 2 B2C(Large) Invoices – 5A, 5B of GSTR-1 report.
  • Nature of transaction
  • Registration Type as
    • Unregistered
    • Consumer
  • Unregistered party selected in the Party Details screen for sales made by selecting e-commerce operator in the Party’s A/c Name field.
  • When the taxable stock item is selected along with exempted or nil-rated goods, then the values are captured here. If only exempted or nil rated goods are selected, it will appear under the Nil Rated Invoices table of GSTR-1 report.
  • Interstate sales of more than Rs. 2,50,000 to unregistered dealers and consumers are captured here.
Invoice Number
Displays the voucher number of the outward supply transaction.
If the length of the voucher number is more than 16 characters, including the special characters, the offline tool will display a validation error.
Invoice date
Invoice Value
Displays the total value in the invoice including tax and cess.
Place Of Supply
Rate
Taxable Value
Cess Amount
E-Commerce GSTIN
b2cs
Displays the details of table 3 B2C(Small) Invoices – 7 of GSTR-1 report.
Displays the net values of sales, for transactions recorded with:
  • Nature of transaction as:
    • Sales Taxable
    • Sales to Consumer – Taxable
    • Sales to Consumer – Exempt
    • Sales Nil Rated
    • Sales Exempt
  • Taxability as:
    • Taxable
    • Exempt
    • Nil Rated
  • Registration Type as:
    • Unregistered
    • Consumer
  • When a taxable stock item is selected along with exempted or nil-rated goods, then the values are captured here. If only exempted or nil rated goods are selected, it will appear under the Nil Rated Invoices table of GSTR-1 report.
  • Interstate sales of equal to or less than Rs. 2,50,000 to unregistered dealers and consumers are captured here.
Type
Displays E for e-commerce party and OE for others.
Place Of Supply
Rate
Taxable Value
Cess Amount
E-Commerce GSTIN
cdnr
Displays the details of table 4 Credit/Debit Notes (Registered) – 9B of GSTR-1 report.
Displays the values of credit and debit notes recorded in the reporting period with the following details:
  • Sales Taxable
  • Sales Exempt
  • Sales Nil Rated
Taxability as:
  • Taxable
  • Exempt
  • Nil Rated
Journal voucher recorded by debiting GST ledgers with:
  • Nature of Adjustment- Decrease of Tax Liability
  • Additional Details – Cancellation of Advance Receipts or Cancellation of Advance Receipts for Exports/SEZ sales
Displays the GSTIN/UIN entered in the Party Details screen of the debit/credit note.
Displays the GSTIN/UIN entered in the Statutory Details screen of the journal voucher recorded for the cancellation of advance receipt.
Invoice/Advance Receipt Number
Displays the Original invoice no. entered in the debit/credit note.
Displays the Advance Receipt Number entered in the Statutory Details screen of the journal voucher recorded for the cancellation of advance receipt.
Special characters other than “-” and “/” in the Original invoice no. or Advance Receipt Number are not exported.
If the length of the Original invoice no. or Advance Receipt Number is more than 16 characters, including special characters, the offline tool will display validation error.
Invoice/Advance Receipt date
Displays the Original Invoice Dt. of debit/credit note.
Displays the Advance Receipt Date entered in the journal voucher recorded for the cancellation of advance receipt.
Note/Refund Voucher Number
Displays the voucher number of debit/credit note.
Displays the Refund Voucher Number entered in the journal voucher recorded for the cancellation of advance receipt.
Note/Refund Voucher date
Displays the debit/credit note date.
Displays the Refund Voucher Date entered in the journal voucher recorded for the cancellation of advance receipt.
Document Type
Displays the document type based on the voucher type:
  • C for Credit Note
  • D for Debit Note
  • R for journal voucher
Place Of Supply
Displays the Place of Supply entered in the Statutory Details screen of the journal voucher recorded for the cancellation of advance receipt.
Note/Refund Voucher Value
Displays the total value of the voucher.
Rate
Taxable Value
Cess Amount
Pre GST
Displays Y if the Original Invoice Dt. entered is prior to 1-Jul-2017, else N.
cdnur
Displays the details of table 5 Credit/Debit Notes (Unregistered) – 9B of GSTR-1 report.
Displays the values of credit and debit notes, recorded in the reporting period with the following details:
  • Interstate Sales Taxable and Interstate Sales Exempt – sales returns made against 2 B2C(Large) Invoices – 5A, 5B table
  • Exports Taxable
  • Exports LUT/Bond
  • Exports Exempt
  • Nature of Adjustment – Decrease of Tax Liability
UR Type
Displays:
  • B2CL if the nature of transaction is of interstate sales.
  • EXPWP, if the nature of transaction is selected as Exports Taxable and Exports Exempt.
  • EXPWOP, if the nature of transaction is selected as Exports LUT/Bond.
Displays the voucher number of payment, debit note, and credit note.
Displays the Refund Voucher Number entered in the journal voucher.
Special characters other than “-” and “/” in the Original invoice no. are not exported.
If the length of the Original invoice no. is more than 16 characters, including special characters, the offline tool will display a validation error.
Displays the voucher date of payment, debit note, and credit note.
Displays the Refund Voucher Date entered in the journal voucher.
The voucher number entered in the GST Details screen of journal voucher appears here.
Document Type
  • C for Credit Note
  • D for Debit Note
Displays the original invoice number of sales or advance receipt linked to credit note and debit note.
Displays the Advance Receipt Number entered in the Statutory Details screen of journal voucher.
Displays the original voucher date of sales or advance receipt linked to credit note and debit note.
Displays the Advance Receipt Date entered in the journal voucher.
Place Of Supply
For transactions recorded with Exports Taxable, Exports Exempt, and Exports LUT/Bond, the place of supply is captured as 97-Other Territory.
Displays the total value in the voucher.
Rate
Displays the integrated tax rate with decimal places. If the stock item is exempt, the tax rate appears as 0.00.
Taxable Value
Cess Amount
Pre GST
exp
Displays the details of table 6 Exports Invoices – 6A of GSTR-1 report.
Displays the values of export sales recorded in the reporting period with the following details:
  • Exports Taxable
  • Exports – LUT/Bond
  • Exports Exempt
Export Type
Displays the export type as:
  • WPAY for sales recorded with Exports Taxable or Export Exempt as the nature of transaction.
  • WOPAY for sales recorded with Exports LUT/Bond as the nature of transaction.
Invoice Number
Displays the sales voucher number entered in the transaction.
If the length of voucher number is more than 16 characters, including the special characters, the offline tool will display a validation error.
Invoice date
Displays the sales voucher date of the transaction.
Invoice Value
Displays the total value of the sales voucher based on tax rates.
Port Code
Displays the Port Code of 6 characters entered in the Statutory Details screen of the sales invoice. If the length of Port Code is more than 6 characters, the offline tool will display validation error.
Shipping Bill Number
Displays the Shipping bill no. entered in the Statutory Details screen of the sales invoice.
Shipping Bill Date
Displays the shipping bill Date entered in the Statutory Details screen of the sales invoice.
Rate
If the nature of transaction selected is Exports Exempt or Exports LUT/Bond, the tax rate appears as 0.00.
Taxable Value
Cess Amount
at
Displays the details of table 7 Tax Liability (Advances received) – 11A(1), 11A(2) of GSTR-1 report.
Displays the credit values of tax entered in journal voucher recorded with the following details:
Nature of Adjustment – Increase of Tax Liability
Additional Details
  • On Account of Advance Receipts
  • Advance Receipts for Export/SEZ sales
Place Of Supply
Rate
Gross Advance Received
Cess Amount
atadj
Displays the details of table 8 Adjustment of Advances – 11B(1), 11B(2) of GSTR-1 report.
Displays the debit values of tax entered in journal voucher recorded with the following details:
Additional Details
  • Sales against Advance Receipts
  • Sales against Advance Receipts for Export/SEZ sales
Place Of Supply
Displays the State Name and state Code based on the Place of Supply of the buyer in Party Details screen of the voucher.
Displays the Place of supply entered in the Statutory Details screen of journal voucher.
Rate
Gross Advance Adjusted
Cess Amount
exemp
Displays the details of table 9 Nil Rated Invoices of GSTR-1 report.
Displays the net values of nil rated, exempt, and non-GST outward supplies made to registered and unregistered dealers within and outside the state.
Description
Displays the description as:
  • Inter-State supplies to registered/unregistered persons
  • Intra-State supplies to registered/unregistered persons
Nil Rated Supplies
Displays the net sale value of nil rated supplies made to registered or unregistered dealers within or outside the state.
Exempted (other than nil rated/non GST supply)
Displays the net sale value of exempt supplies made to registered or unregistered dealers within or outside the state.
Non-GST supplies
Displays the net sale value of non-GST goods sold to registered or unregistered dealers within or outside the state.
hsn
Displays the details of table 10 HSN wise Summary – 12 of GSTR-1 report.
Displays the HSN of stock items/groups.
HSN
Displays the HSN/SAC predefined for the ledger, stock group, or stock item selected in the voucher.
Description
Displays the Description of the HSN/SAC predefined for the ledger, stock group, or stock item selected in the voucher. If HSN or HSN description is not defined for stock items and ledgers, the name of the stock items and ledgers are displayed.
UQC
Displays the Unit Quantity Code (UQC) predefined for the unit of measure linked to the stock item selected in the voucher.
Displays the UQC as OTHERS-OTH for services.
Total Quantity
Displays the total quantity based on HSN/SAC and UQC.
Total Value
Displays the voucher value based on HSN/SAC and UQC.
Taxable Value
Displays the assessable value based on HSN/SAC and UQC.
Integrated Tax Amount
Displays the integrated tax amount based on HSN/SAC and UQC.
Central Tax Amount
Displays the central tax amount based on HSN/SAC and UQC.
State/UT Tax Amount
Displays the state tax amount based on HSN/SAC and UQC.
Cess Amount
Displays the cess amount based on HSN/SAC and UQC.
docs
Displays the details of the Document Summary report
Nature of Document
Displays the transaction count of voucher type used for each nature of documents recorded during the return period.
Sr. No. From
Displays the first voucher number of the voucher type recorded for each nature of document during the return period.
Sr. No. To
Displays the last voucher number of the voucher type recorded for each nature of document during the return period.
Total Number
Displays the number of vouchers as per each nature of document recorded during the return period.
Cancelled
Displays the number of vouchers cancelled during the return period.
