View Daily Stock Register (Excise for Manufacturer)
A registered manufacturer has to maintain duty details of finished goods in the form of a Daily Stock Register.
- Gateway of Tally > Display More Reports > Statutory Reports > Central Excise Reports > Manufacturer > Daily Stock Register.
Alternatively, press Alt+G (Go To) > type or select Daily Stock Register. - Select the Name of excise unit.
- Enter the period.
- Select the item required.
- Select the Name of tariff and Reporting UoM.
- Press Enter.
You can view the stock item and the duty details for every day.
