HomeTallyPrimeBanking UtilitiesConnected Banking - FAQ
 PDF
Connected Banking – FAQ
Login and Logout
You can create a new Tally.NET ID. Thereafter, the admin can approve the access to Connected Banking for you.
To know more, refer to Approve User Access to Connected Banking for non-admin users.
You need to ask your Tally partner to update your e-mail address under the license.
Thereafter, you can Set Up Connected Banking using your mobile number.
If you do not know your e-mail address, then you can get it from the license information.
In TallyPrime, press F1 (Help) > Settings > License > Manage License.
If you know the password of your e-mail, then you can also change your e-mail address on the Tally Solutions customer portal.
If the e-mail address and password are not available, then you will need to get in touch with TallyCare.
If you are the license owner, then ask your accountant to log in to the Tally Solutions customer portal and change the e-mail address associated with the license.
However, if you are not able to change the e-mail address or do not have access to the account, then contact Tally Solutions.
The If you are the license owner, then ask your chartered accountant to log in to the Tally Solutions customer portal and change the e-mail address associated with the license.
Even if your Tally.NET ID and the e-mail address registered with the bank are different, you can still use the Connected Banking services in TallyPrime.
To know more, refer to log in or register for Connected Banking.
You need to log in because of a period of inactivity for more than 15 minutes.
In such a case, you will need to enter your Tally.NET password to make the session active.
To know more, refer to Log in to Connected Banking when the session is expired or inactive.
Based on the bank accounts you want to connect to TallyPrime, refer to the below table to know the criterion for linking mobile number to your Tally.NET ID:
Sl No. Bank Name Criterion for Linking Mobile Number to Tally.NET ID
1 Axis Bank (India) You can link any mobile mobile to your Tally.NET ID.
2 Kotak Mahindra Bank (India) You can link any mobile mobile to your Tally.NET ID.
You need to change the password, because the password policy has been updated from TallyPrime Release 6.0 for the Connected Banking users.
Your new Password should either be a 6-10 digit PIN or contain at least 8 characters with one uppercase letter, one lowercase letter, a number, and a special character.
No, an account administrator does not require any approval, as Connected Banking is enabled for all administrators. However, you will need to link a mobile number to your Tally.NET ID, before you can begin to use Connected Banking.
In such a case, you can change the mobile number on the Tally Solutions customer portal:
  1. Click My Profile.
  2. Enter the new mobile number.
  3. Accept the terms and conditions.
  4. Click Update.
Check your internet connection and try again.
Alternatively, you can reset the Connected Banking login.
  1. Press F1 (Troubleshooting) > Reset Connected Banking Login and press Enter.
  2. Press Y to confirm.
You can try to reconnect your bank accounts to TallyPrime.
To know more, refer to Reconnect Bank Accounts.
If you are an Axis Bank user for Corporate Login, then ensure that the Connected Banking request is approved by the approver selected when you initiated the connection.
To know more, refer to Connect Your Axis Bank Accounts | Multiple Users with Authorisation by Approver.
No, the bank login credentials does not get stored in TallyPrime.
However, you connect to bank from TallyPrime with your Tally.NET ID. Thereafter, your bank accounts get linked.
TallyPrime stores the information that you have connected to bank using your Tally.NET ID.
Therefore, the bank accounts get linked for your Tally.NET ID.
You can link any mobile number to your Tally.NET ID when you are registering for Connected Banking in TallyPrime.
To know how to do it, refer to Link mobile number to Tally.NET ID.
You can also link a mobile number to your Tally.NET ID on the Tally Solutions Customer Portal.
The users, who have connected bank accounts, using their Tally.NET credentials can get the Bank Balance and Bank Statement.
No, the user gets approval to log in only on a computer with a specific license. If a user wants to access Connected Banking in a computer with a different license, then an approval from the Account Administrator will be required.
Here are the steps to follow if you are not receiving an OTP.
  1. Check if the number entered is a 10-digit valid mobile number.
  2. If the mobile number is correct, then press Alt+H (Resend OTP).
  3. If you still don’t receive an OTP on your mobile number, then contact Tally Solutions.
  1. Press Alt+H (Resend OTP).
  2. If you still don’t receive an OTP on your mobile number, then contact Tally Solutions.
Yes, a valid license and TSS are needed to use the Connected Banking services and the enhanced reconciliation features available in TallyPrime Release 6.0.
This happens because the Connected Banking session is not available in the License Gateway.
Get Balance
To check Bank Balance in TallyPrime:
  1. Press Alt+Z (Exchange) > Get Balance.
    Alternatively, press Alt+Z (Exchange) > All Banking Options > Get Balance.
  2. Select one or more bank accounts to get the balance.
  3. Press B (Get Balance).
To know more, refer to Get Bank Balance.
Your Axis Bank ledger gets listed in the Get Statement or Get Balance report, you need to ensure the following:
You also need to ensure the following:
  • In the Bank Connections report, the status of the connection is Connected.
  • The account number in the Bank Connection matches the one in the bank ledger.
To resolve this, you need to:
  1. Press Alt+B (Bank Connections) > Connect/Reconnect, as needed.
  2. Update the correct account number in the bank ledger with no spaces between or after the number.
Get Statement
You can import Bank Statement online right from the bank through Connected Banking.
To know how to do it, refer to Get Bank Statement.
You can get statements only from the banks supported for Connected Banking in TallyPrime.
To view the list of banks supported for Connected Banking, press Alt+Z (Exchange) > All Banking Options > Bank Connections.
Press F6 (New Connection).
The list of supported bank gets displayed.
To know more, refer to Connect Bank Accounts.
If the status of a request is Pending at Bank, then you can click Get Statement to refresh the status.
If the Statement has been received from the bank, then it will get imported.
You can also delete the required and request a statement all over again.
To know more, refer to Get Bank Statement.
Once the statement is ready to import, you can click Get Statement to import the statement.
To know more, refer to Import Bank Statement.
Press Alt+B Bank Connections. You need to Connect/reconnect your bank accounts to TallyPrime.
Currently, Axis Bank does not provide a running balance after you import the Bank Statement. So, Balance as per Bank Statement is not displayed in the Bank Reconciliation Summary and Imported Bank Data report.
If you want to verify the bank balance against books, then you can check the Expected Bank Balance in the report and also the balance on the bank portal.
For real-time balance, you can get bank balance right from TallyPrime.
The bank ledger does not get listed due to one of the following reasons:
  1. The ledger is not created.
  2. The bank name is not selected in the ledger.
It might also be possible that you have not connected your bank accounts.
To know how to do it, refer to Connect Bank Accounts.
Bank Connections
When you do not want to use bank accounts through Connected Banking, you can disconnect your Bank accounts from TallyPrime.
To know how to do it, refer to Disconnect Bank Accounts.
You can reconnect your bank accounts in the same way you connect them.
To know how to do it, refer to Reconnect Bank Accounts.
You can refer to the validity of a Connection under the Validity column in the Bank Connections report.
For example, the validity of the Connection ID for Axis and Kotak Mahindra Banks is 30 days.
The following are the prerequisites to get started with Connected Banking:
  1. Active license
  2. Valid TSS
  3. Tally.NET ID or a valid e-mail address
  4. Valid 10-digit mobile number for linking with your Tally.NET ID and receiving OTP
You can then Connect Your Bank Accounts for Connected Banking.
A Connection ID is generated at the time of connecting your Bank accounts to TallyPrime.
In case of Axis Bank (India) and Kotak Mahindra Bank (India), you don’t need to enter the Connection ID on the portal. It is automatically recognised by the Bank when you initiate a connection on the Bank portal.
In case of State Bank of India (SBI), the Connection ID is required to validate the connection on the Bank portal.
If you do not reconnect bank accounts to TallyPrime, then the Connection gets automatically removed after a certain period of time.
While reconnecting, the Connection ID remains the same.
If you are an Axis Bank customer with a Retail login, then you can re-open the Bank Connections report where the latest status will get updated.
However, if you are an Axis Bank customer with a Customer login, then you need an approval from the bank admin. After approval, the status will be displayed as Connected.
When you connect to bank from TallyPrime, a Connection ID gets generated. Once the Connection is established, all the bank accounts related to the bank connection or CRN get connected to TallyPrime.
The Connection Status of your existing Bank Connection will changed to Expired.
So, you will need to reconnect the expired Bank Connection by following all the steps under Connect Your Axis Bank Accounts | Neo for Corporates with Multiple Users.
There can be three reasons because of which the website does not load in the browser:
Sl No. Possible Reason Solution
1 The website is blocked in the Windows Firewall. You can add URL to Windows Proxy or Firewall Exceptions List.
2 You are using TallyPrime on cloud. Contact your cloud provider to get access to the website.
3 The website doesn’t load due to enhanced browser security.
To resolve this, follow the steps given below:
  1. Go to Tools > Internet Options > Security.
  2. Select Trusted sites and click Sites.
  3. Add the URL of the trusted website and click Add.
The error occurs, because Axis Bank supports only Current accounts for Connected Banking and not the Savings accounts.
3 Website doesn’t load due to enhanced browser security.
Yes, you can connect all the accounts if the entities or company accounts are linked to the same login credentials on the bank portal.
However, in case of different login credentials for different entities or company accounts, you will need to initiate new connection from TallyPrime for all the accounts separately.
If you have an Axis Bank account, then you can use Connected Banking.
Refer to Account and Platform Types Supported | Axis Bank to know the criteria for connecting your bank accounts to use Connected Banking in TallyPrime.
To connect your bank accounts and use Connected Banking in TallyPrime, you need to have the transaction maker rights.
Refer to Account and Platform Types Supported | Axis Bank to know more.
If you have a Kotak Mahindra Bank account, then you can use Connected Banking.
Refer to Account and Login Types Supported | Kotak Mahindra Bank to know the criteria for connecting your bank accounts to use Connected Banking in TallyPrime.
This error occurs due to one of the following reasons:
  1. The net banking is not enabled for you. So, you might have connected with the User ID.
    You need to enable net banking for your bank account.
  2. You might have initiated the connection with the same CRN again, with a different Tally.NET ID.
    You need to initiate connection with the same Tally.NET ID.
Helpful?
