HSN Summary Is Not Getting Exported/Uploaded
Cause 1:
Invalid HSN/SAC or incorrect HSN digit length (4 vs 6 vs 8 digits)
Resolution 1:
- Verify HSN/SAC details in your stock item and ledger master.
- Ensure that the HSN contains valid digits as per your annual turnover.
Cause 2:
Mismatch between HSN/SAC and supply type.
Resolution 2:
Resolve Mismatch between HSN/SAC and Type of Supply.
Cause 3:
Some transactions are part of Uncertain Transactions section of the GSTR-1 due to missing or invalid HSN/SAC.
Resolution 3:
- Resolve all the Uncertain Transactions to ensure all vouchers are uploaded correctly into the respective tables of GSTR-1.
- Update the HSN/SAC Summary report.
Cause 4:
The Export configuration for GSTR-1 is not set properly.
Resolution 4:
- Press Alt+O (Export) > GST Returns.
- In the GSTR-1 Export screen, press Ctrl+B (Basis of Value) and enable Include HSN Summary and Include Document Summary.
