Tally Compliant Product – TCP File
Tally Compliant Product (.tcp) file is a compiled and validated TDL project which can be executed in TallyPrime. To generate a single executable TCP file, it is mandatory to compile a project file. When you compile a project, all TDL program files are automatically combined and compiled, along with the main TDL program file.
To build a TCP file
  • Click the option Build from the Build menu, or press F9.
Or
  • Select the required project from the Project Browser, right-click, and click Build.
Or
  • Click Save And Build while setting/altering the project properties in the Project Properties window. This will save the project properties, and also build the project to create a TCP file simultaneously.
