HomeDeveloper ReferenceTally Definition LanguageSchema and Invoice ChangesDeveloper Guide for KSA e-Invoicing Integration Phase
Storage (UDFs)
 Company Object
Storage (UDFs)
Type
Description
IsKSAPhase2Applicable
Logical
Enablement of the integration phase
KSAPhase2ApplicableDate
Date
Integration phase start date
KSA_Einv_Detail_VRNType
String
Company VRN Type Selection as per company criteria
1)  Company Registration
2)  Headquarter Registration
KSA_Einv_Detail_CRN
String
Commercial Registration No
KSA_Einv_Detail_MOM
String
Momrah License
KSA_Einv_Detail_MLSD
String
MHRSD License
KSA_Einv_Detail_Sagia
String
MISA license
KSA_Einv_Detail_OtherId
String
Other ID Name
KSA_Einv_Detail_IDNumber
String
Other ID
KSA_Einv_Detail_BuildingNo
String
Building No.
KSA_Einv_Detail_City
String
City
KSA_Einv_Detail_District
String
District
KSA_Einv_Detail_700No
String
700 No.
CMP_KSA_Pincode
String
Pincode
Cmp_KSA_State_Arabic
String
State name In Arabic
KSAEInvoiceArchivePathPhase2
String
ZATCA Compliance XML and PDF A3 Archive Path for integration phase
CMPeInvEndDate
Date
Generation Phase End Date
GVatCMP_KSA_City
String
City in Arabic
GVatCMP_KSA_District
String
District in Arabic
CMPeInvApplicableDate
Date
Generation Phase Start Date
IsCMPeInvApplicable
logical
Generation phase Enablement
KSA_Einv_Detail_OtherId_Arabic
String
Storage Implemented for “Other ID” Description in Arabic Language
Additional storage has been implemented for Arabic details in the multi-address form. The existing storage will be used for other fields. Below, we have mentioned the additional address fields specifically added for the Arabic language in the multi-address form:
Storage (UDFs)
Type
Description
CompanyAddressNative_Aggr_KSA
Aggregate
Aggregate Used for Arabic Address in Multi-Address Form
CompanyNameNative_AddrType_KSA
String
Arabic Name of the company
CompanyAddressNative_AddrType_KSA
Date
Arabic Address of the company
CompanyCountryNative_AddrType_KSA
String
City in Arabic
Additional storage has been added for the region in English in the multi-address form:
StateName_AddrType_KSA
String
Region of the company
Ledger Object
Storage (UDFs) Type Description
Ledger_KSA_VRN_Type  String  Ledger VRN Type Selection as per company criteria
LED_BuyerlD_Details_TIN  String  Tax Identification Number
LED_BuyerlD_Details_CRN  String  Commercial Registration No.
LED_BuyerlD_Details_MOM  String  Momrah License
LED_BuyerlD_Details_MLSD  String  MHRSD License
LED_BuyerlD_Details_s700  String  700(Only for B2C)
LED_BuyerlD_Details_Sagia  String  MISA License
LED_BuyerlD_Details_NationlID  String  National ID
LED_BuyerlD_Details_GCCId  String  GCC ID
LED_BuyerlD_Details_Iqma_Number  String  Iqama Number (IQA)
LED_BuyerlD_Details_PassportID  String  Passport ID
LED_BuyerlD_Details_OtherId  String  ID Name
Ledger_KSA_BuildingNo  String  Building Number
Ledger_KSA_City  String  Ledger City
Ledger_KSA_District  String  Ledger District
Ledger_KSA_Pincode  String  Ledger Pincode
LedgerCategoryReason  String  If Taxability is under Zero rated, Exempt, Not VATABLE then Reason is mandatory for e-Invoice generation (Selection is available in Ledger Master). List of code and its details added in a table below
LedgerCategoryReasonCode  String  If Taxability is under Zero rated, Exempt, Not VATABLE then Reason is mandatory for e-Invoice generation (Selection is available in Ledger Master). List of code and its details added in a table below
Ledger_TypeofCharges   String  A dropdown will be available with 172 options mapped with charge codes. (Selection is available in Ledger Master). List of code and its details added below.
Ledger_ChargeCode  String  A dropdown will be available with 172 options mapped with charge codes (you can find Charges Code details) for einvoice generation charges code is mandatory. Condition: This field is to be added when the parent group name is one of the following:
1.     Direct Expenses
2.     Direct Incomes
3.     Expenses (Direct)
4.     Expenses (Indirect)
5.     Income (Direct)
6.     Income (Indirect)
7.     Indirect Expenses
8.     Indirect Incomes
LedgerCategoryReasonArabic  String  In case of non-vatable ledger Arabic reason is mandatory
Ledger_KSA_AdditionalID  String  Ledger Addition ID
 GVatLedger_KSA_City  String  Ledger City in Arabic
 GVatLedger_KSA_District  String  District in Arabic
LED_BuyerlD_Details_IdNo  String  Other ID No
 DescriptionKSAArabic  String  Arabic Description storage Added in Ledger master and item master
GVatLedger_KSA_state  String  Ledger State in Arabic
LED_BuyerlD_Details_OtherId_Arabic String Additional ID description in Arabic for the Party Ledger
Stock Item Object
ItemCategoryReason  String  Exempt, Not VATABLE then Reason is mandatory for e-Invoice generation (Selection is available in Item Master) (List of code and its details added below)
ItemCategoryReasonCode  String  If Taxability is under Zero rated, Exempt, Not VATABLE then Reason code is mandatory for e-Invoice generation (List of code and its details added below)
ItemCategoryReasonArabic  String  In case of non-vatable ledger Arabic reason is mandatory
Voucher Object
einvoice_generate_Status  String  Value Should be “P” if e-Invoice get generated
einvoice_signedInvoice  String After successful generation of e-Invoice signedInvoice receiving from e-Invoicing system
einvoice_signedQRCode  String  After successful generation of e-Invoice signedQRCode receiving from e-Invoicing system
einvoice_qrCode  String  After successful generation of e-Invoice qrCode receiving from e-Invoicing system
einvoice_qrCodeData  String  After successful generation of e-Invoice qrCodeData receiving from e-Invoicing system
einvoice_qrCodeHash  String  After successful generation of e-Invoice qrCodeHash receiving from e-Invoicing system
einvoice_qrCodeUUID  String  After successful generation of e-Invoice UUID receiving from e-Invoicing system
OverrideCategoryReasonCode  String The Code for the category reason, which has been overridden in the transaction
OverrideCategoryReason String The description for the category reason, which has been overridden in the transaction, in English
OverrideCategoryReasonArabic String The description for the category reason, which has been overridden in the transaction, in Arabic
VchWarningMsg  String  After successful generation of E-Invoice if any Warning comes then it will store in this UDF
VchErrorMsg  String  If any document rejected from E-Invoice System, then rejected reason will store in this UDF
VchRejectEinvoice  Logical If any document rejected from E-Invoice System this method should be “yes”
VcheInvAmountDue   Amount  The outstanding amount that is requested to be paid. This amount is the Invoice total amount with VAT minus the pre-paid amount that has been paid in advance plus Rounding Amount. The amount is zero in case of a fully paid Invoice.
CreditnoteCodeKSA  String  Credit note Reason code is required for e-Invoicing (List of code and its details below)
ReceiptCategoryReason  String  If Taxability is under Zero rated, Exempt, Not VATABLE then Reason is mandatory for e-Invoice generation (Selection is available in receipt Transaction Advance Payment scenario)
ReceiptCategoryReasonCode  String  If Taxability is under Zero rated, Exempt, Not VATABLE then Reason is mandatory for e-Invoice generation (Selection is available in receipt Transaction Advance Payment scenario)
einvoice_generatedDateKSA  String  e-Invoice Generated Date
einvoice_generatedTimeKSA  String  e-Invoice Generated Time
KSAGVATTransNature  String  Nature of transaction UDF Added in Receipt Transaction in Advance Payment Scenario.
KSA_CategoryCode_Export_GCC_Excempt  String  If Party ledger belongs to unregistered and non KSA Country, then at voucher level User must select Category Code and its reason for e-Invoicing.
KSA_CategoryCode_Nonvatable_Reason  String  If Party ledger belongs to unregistered or non KSA Country, then at voucher level UDF Added under show e-invoice Details.
KSA_CategoryCode_Nonvatable_Reason_Arabic  String  If Party ledger belongs to unregistered or non KSA Country, then at voucher level UDF Added under show e-invoice Details.
VcheInvAdvanceAmount  Amount  Advance Amount UDF added under show e-invoice Details.
VCHAddressNativeAggr  String  Aggregate added in supplementary details for buyer address in Arabic under mailing details in local language
VchMailingNameNative  String  Mailing name in Arabic added in supplementary details under mailing details in local language
VCHAddressNative  String  Mailing address in Arabic added in supplementary details under mailing details in local language
VCHCityNative  String  City name in Arabic (party details in supplementary form) under mailing details in local language
VCHDistrictNative  String  district in Arabic (party details in supplementary form) under mailing details in local language
BasicUserDescriptionArabicAggr  String  the Arabic basic user description aggregate added below the default item description or ledger description
BasicUserDescriptionArabic  String  Arabic Basic User Description Storage Added below default item description or ledger description
ReceiptCategoryReasonArabic  String  in case of non-vatable Arabic category Reason is mandatory in advance receipt storage added for user input
VCHeInvTotalAmt_KSA_Integ_phase  Amount  Total invoice Amount
VCHeInvVATAmt_KSA_Integ_phase  Amount  Total Vat Amount
VCHeInvActualAmt_KSA_Integ_phase  Amount  Total invoice Amount for which e-invoice generated (to check tempered Invoice)
TaxNatureTrans  String  Nature of transaction in advance receipt Voucher
VCHeInvCompanyName   String  Company name
VCHeInvVATNumber  String  Party vat tin number
VCHeInvTime  String  Invoice generated Time
VCHeInvDate  String  Invoice date
TaxNatureTrans String Added nature of transaction in Advance Receipt
KSA_Vch_TypeofAddress String Added Storage for Address Type Selection in Voucher Level under ‘Show E-Invoice Details’ to Use Multi-Address value.
Credit Note / Debit Note Reason List
Code Description
CAN  Cancellation or suspension of the supplies after its occurrence either wholly or partially
ASUP  In case of essential change or amendment in the supply, which leads to the change of the VAT due
ASUPV  Amendment of the supply value which is pre-agreed upon between the supplier and consumer
REF  In case of goods or services refund
CHG  In case of Change in Seller’s or Buyer’s information
VAT Category Code and Text
Exemption from Tax
Code  English Text
VATEX_SA_29  Financial services mentioned in Article 29 of the VAT Regulations
VATEX_SA_29_7  Life insurance services mentioned in Article 29 of the VAT Regulations
VATEX_SA_30  Real estate transactions mentioned in Article 30 of the VAT Regulations
Zero rated goods
Code English Text
VATEX_SA_32  Export of goods
VATEX_SA_33  Export of services
VATEX_SA_34_1  The international transport of Goods
VATEX_SA_34_2  International transport of passengers
VATEX_SA_34_3  Services directly connected and incidental to a Supply of international passenger transport
VATEX_SA_34_4  Supply of a qualifying means of transport
VATEX_SA_34_5  Any services relating to Goods or passenger transportation, as defined in article twenty-five of these Regulations
VATEX_SA_35  Medicines and medical equipment
VATEX_SA_36  Qualifying metals
VATEX_SA_EDU  Private education to citizen
VATEX_SA_HEA  Private healthcare to citizen
VATEX_SA_MLTRY  Supply of qualified military goods
VATEX_SA_EDU
VATEX_SA_HEA
VATEX_SA_MLTRY
 Services outside scope of tax / Not subject to VAT/(Non Vatable)
Code
English Text
VATEX_SA_OOS
Reason is free text, to be provided by the taxpayer on case-to-case basis.
Charges Ledger Master Code list
Code
Ledger Name
AA
Advertising allowance
AAA
Telecommunication charges
AAB
Returned goods charges
AAC
Modification costs
AAD
Job-order production
AAE
Outlays
AAF
Off-premises surcharge
AAG
Gold surcharge
AAH
Processing surcharge
AAI
Attestation fee
AAJ
Copper surcharge
AAK
Energy surcharge
AAL
Deduction for missing parts
AAM
Rubber surcharge
AAN
Brass surcharge
AAO
Material surcharge/deduction
AAP
Lead surcharge
AAQ
Price index surcharge
AAR
Platinum surcharge
AAS
Acceptance cost
AAT
Rush delivery
AAV
Special construction charge
AAY
Airport facilities
AAZ
Concession
ABA
Compulsory storage
ABB
Fuel removal
ABC
Into plane
ABD
Overtime
ABF
Tooling
ABK
Miscellaneous
ABL
Additional packaging
ABN
Dunnage
ABR
Containerisation
ABS
Carton packing
ABT
Hessian wrapped
ABU
Polyethylene wrap packing
ACF
Miscellaneous treatment
ACG
Enamelling treatment
ACH
Heat treatment
ACI
Plating treatment
ACJ
Painting
ACK
Polishing
ACL
Priming
ACM
Preservation treatment
ACS
Fitting
ADC
Consolidation
ADE
Bill of lading
ADJ
Airbag
ADK
Transfer
ADL
Slipsheet
ADM
Binding
ADN
Repair or replacement of broken returnable package
ADO
Efficient logistics
ADP
Merchandising
ADQ
Product mix
ADR
Other services
ADT
Pick-up
ADW
Chronic illness
ADY
New product introduction
ADZ
Direct delivery
AEA
Diversion
AEB
Disconnect
AEC
Distribution
AED
Handling of hazardous cargo
AEF
Rents and leases
AEH
Location differential
AEI
Aircraft refueling
AEJ
Fuel shipped into storage
AEK
Cash on delivery
AEL
Small order processing service
AEM
Clerical or administrative services
AEN
Guarantee
AEO
Collection and recycling
AEP
Copyright fee collection
AES
Veterinary inspection service
AET
Pensioner service
AEU
Medicine free pass holder
AEV
Environmental protection service
AEW
Environmental clean-up service
AEX
National cheque processing service outside account area
AEY
National payment service outside account area
AEZ
National payment service within account area
AJ
Adjustments
AU
Authentication
CA
Cataloguing
CAB
Cartage
CAD
Certification
CAE
Certificate of conformance
CAF
Certificate of origin
CAI
Cutting
CAJ
Consular service
CAK
Customer collection
CAL
Payroll payment service
CAM
Cash transportation
CAN
Home banking service
CAO
Bilateral agreement service
CAP
Insurance brokerage service
CAQ
Cheque generation
CAR
Preferential merchandising location
CAS
Crane
CAT
Special colour service
CAU
Sorting
CAV
Battery collection and recycling
CAW
Product take back fee
CD
Car loading
CG
Cleaning
CS
Cigarette stamping
CT
Count and recount
DAB
Layout/design
DAD
Driver assigned unloading
DL
Delivery
EG
Engraving
EP
Expediting
ER
Exchange rate guarantee
FAA
Fabrication
FAB
Freight equalization
FAC
Freight extraordinary handling
FC
Freight service
FH
Filling/handling
FI
Financing
GAA
Grinding
HAA
Hose
HD
Handling
HH
Hoisting and hauling
IAA
Installation
IAB
Installation and warranty
ID
Inside delivery
IF
Inspection
IR
Installation and training
IS
nvoicing
KO
Koshering
L1
Carrier count
LA
Labelling
LAA
Labour
LAB
Repair and return
LF
Legalisation
MAE
Mounting
MI
Mail invoice
ML
Mail invoice to each location
NAA
Non-returnable containers
OA
Outside cable connectors
PA
Invoice with shipment
PAA
Phosphatizing (steel treatment)
PC
Packing
PL
Palletizing
RAB
Repacking
RAC
Repair
RAD
Returnable container
RAF
Restocking
RE
Re-delivery
RF
Refurbishing
RH
Rail wagon hire
RV
Loading
SA
Salvaging
SAA
Shipping and handling
SAD
Special packaging
SAE
Stamping
SAI
Consignee unload
SG
Shrink-wrap
SH
Special handling
SM
Special finish
SU
Set-up
TAB
Tank renting
TAC
Testing
TT
Transportation – third party billing
TV
Transportation by vendor
V1
Drop yard
V2
Drop dock
WH
Warehousing
XAA
Combine all same day shipment
YY
Split pick-up
ZZZ
Mutually defined
e-Invoice enablement for the voucher type
To enable e-Invoicing for a voucher type; new storage ‘IsVchTypeInvApplicable’ is introduced.
;; to Check e-invoice yes or no
[Field : VTYP KSAInvoiceEnable]
Use              : Logical Field
Storage       : IsVchTypeInvApplicable
Skip on        : $HasVouchers And $IsVchTypeInvApplicable
Set Always  : Yes
QR Code Part
In Comprehensive Invoice
[Part: EXPINV VATGCCQRCodeArabic]
QR Code                  : @SignedQrcode:Yes
SignedQrcode         : @@PrintafterSaveQR (formula Added below)
Line                           : VATGCCQRCodeDetails
Common Border     : Yes
Invisible                    : $$IsEmpty:@@PrintafterSaveQR
In Simple Invoice
[Part: EXPSMP VATGCCQRCode]
QR Code            : @SignedQRCode:Yes
SignedQRCode   : @@PrintafterSaveQR (formula Added below)
Line                     : EXPSMPVATGCCQRCodeDetails
In POS Invoice
[Part: KSA_eInvoice PrintExp QRC]
QR Code                 : @SignedQrCode:Yes
SignedQrCode       : @@PrintafterSaveQR
Line                         : Empty
Horizontal Align   : Center
System Formula
[System   : Formula]
 PrintafterSaveQR:If Not $$IsEmpty:$einvoice_signedQRCode then $einvoice_signedQRCode + ElseIf $$number:##MasterID_PrintAfterSave = $$number:$MasterID then ##QRCodeString_PrintAfterSave  +
Else “”
Note : @@EInvoiceQRCodeKsa can be used to print the QR code from previously saved vouchers as required. The key difference is that if the ‘Print after save’ option is enabled in the voucher type, the QR code may not print at that moment. In such cases, you can utilize the formula mentioned above to ensure the QR code is printed.
Function – SubmitForKSAEInvoice
The function is designed to submit a transaction for e-Invoice generation by calling an external import utility or API.
The function will accept a MasterID as input, which corresponds to a specific transaction. This transaction will then be submitted for e-Invoice generation. Upon submission, the function will capture and store the success or failure response directly within the transaction
Example
$$SubmitForKsaEinvoice:(ID:324)
