HomeTallyPrimeGet StartedLicensing Activities
Activate License
All About Licenses | ACTIVATE | Configure | Reactivate | Update | Surrender | Multi-Site
Once you have bought a new TallyPrime license, you will need to activate the same using the license key received on your registered e-mail address. Until you activate your license, your TallyPrime will be in education mode. Got a New TallyPrime License? Activate the license now.
Activate your TallyPrime silver or gold license in your system and get started. If you have a gold license, it is recommended to activate it in a system that can be available all the time as the server system.
To watch our short video, click:
1. Start TallyPrime in Administrator Mode
Right-click the TallyPrime icon in the installation folder, and click Run as Administrator.
2. Start License Activation
  1. In the Welcome to TallyPrime screen, select A (Activate License).
  2. Enter your License Serial Number, Activation Key, and E-mail ID/Tally.NET ID.
    This E-mail address will be set as your Account ID  for this license.
  3. Press Enter to receive the unlock key in your e-mail.
3. Unlock License
  1. In the Unlock License screen, enter the Unlock Key
  2. Press Enter to complete the process.
  3. You have successfully activated your TallyPrime license.
What’s Next
Save the Tally.Net ID and credentials shared via e-mail on activation of license for future license activities.
Questions & Answers
I have not received the license key on the registered e-mail ID. What should I do?
  1. Click the Unlock Key Service screen.
  2. Enter the required license details, and click the Get Unlock Key button.
    If you are still not able to find it, write an e-mail with your license serial number to support.tallysolutions.com and we will get back to you with the details at the earliest.
What should I do if I have forgotten my Tally.NET Password?
Option 1: Update the password on the customer portal.
  1. On the login screen, select Forgot ID/Password.
  2. Click Reset password, enter your Tally.NET ID, enter Captcha, and click Reset.
Option 2: Update the password from TallyPrime
  1. Press F1 (Help) > Settings > Manage License.
    If you are in the Reactivate or Update process, TallyPrime prompts you to enter your ID and password.
  2. Press Alt+R (Reset Password) on the right button bar.
  3. Enter your Tally.NET ID and press Enter.
In both options, you will receive an e-mail notification on your registered e-mail address (your tally.NET ID).
Follow the instructions in the e-mail to setup your password and use the same to login next time.
What if I do not recollect my Tally.NET ID/registered e-mail address?
It is possible that the e-mail address registered is different from the e-mail registered with your Tally.NET ID. Or if you have forgotten your e-mail ID or password, no worries.
Simply write to support.tallysolutions.com with your license details and the correct e-mail address for you Tally.NET ID, and we will get the rest fixed.
How to activate a rejected license?
You can activate a rejected site license using new site ID.
Refer to the video to know the steps to activating a rejected site license.
What should I do, if I am unable to retrieve my license activation key?
Send an e-mail to Tally Support with your e-mail address and the license purchase details. Once we validate the details, you will receive your license activation key in the same e-mail address.
What should I do if I have forgotten my License No. and e-mail ID?
Your TallyPrime license no. should be available from one of the following:
  • F1 (Help) > Settings > License > Manage License.
  • F1 (Help) > About > under License Information.
In case you have forgotten your e-mail address, write an e-mail to Tally Support with the following details:
  • Your license serial number
  • The e-mail address you want to register for your license. Once registered, this will be your registered Tally.NET ID.
  • Your contact details.
Once the details are updated, you will start receiving all license related communication in your registered Tally.NET ID.
You have shared feedback for this page.
