HomeTallyPrimeTallyPrime Cloud AccessVirtual Computer is Running Slow
Cause
Using multiple instances of TallyPrime on Virtual Computer.
Resolution
  1. Log in to the Computer & User Management portal using your Tally.NET ID, Tally.NET Password, and Secure PIN.
  2. Click the ellipsis sign (…) against the account name and select Open Virtual Computer.
  3. Click Start > Help > Task Manager and the CPU usage and Memory are used approximately 100%.
  4. Close the TallyPrime applications, which are opened multiple instances on Virtual Computer.
    We recommend you to use only one TallyPrime instance on Virtual Computer.
