The field unit must be a string with a minimum length of 3 and a maximum length of 8.
Cause
This error occurs when the Unit Quantity Code (UQC) is not updated in the Unit master.
Resolution
  1. Press Alt+G (Go To) > Alter Master > Unit.
  2. Select the name of the Unit for which the invoice is recorded, and press Enter.
  3. Update the Unit Quantity Code (UQC) and save.
Now, generate the e-Invoice again.
