Interstate Purchase with Transfer of Right to Use (VAT)
You can record interstate purchases of tax free goods by selecting the nature of transaction Interstate Purchase Transfer of Right to Use.
This nature of transaction is provided for Odisha.
- Gateway of Tally > Vouchers > press F9 (Purchase).
Alternatively, press Alt+G (Go To) > Create Voucher > press F9 (Purchase). - Enter the Supplier Invoice No. and Date.
- Select the party ledger in the field Party A/c name.
As always, press Alt+C, to create a master on the fly. Alternatively, press Alt+G (Go To) > Create Master > type or select Ledger > press Enter. - Select the purchase ledger predefined with the Nature of transaction set to Interstate Purchase Transfer of Right to Use.
As in other transactions, you can create the ledger on the fly by pressing Alt+C. Alternatively, press Alt+G (Go To) > Create Master > type or select Ledger > and press Enter. - Select the stock item. Enter the Quantity and Rate. The purchase invoice appears as shown below:
- Accept the screen. As always, you can press Ctrl+A to save.
