Increase of Output Tax (VAT)
You can create a journal voucher for the increase in output tax.
  1. Gateway of Tally > Vouchers > press F7 (Journal).
    Alternatively, press Alt+G (Go To) > Create Voucher > press F7 (Journal).
    Note: You can create a journal voucher from  Gateway of Tally > Display More ReportsVAT Reports > select the VAT or CST form.
  2. Press Alt+J (Stat Adjustment). In the Stat Adjustment Details screen,
    • Select the option VAT in the Type of duty/tax field.
    • Select the option Increase of Output Tax in the Nature of adjustment field.
    • Select the option Advance Tax in Additional Details field.
    • Press Enter to save and return to the voucher screen.
  3. Debit the ledger grouped under Current Liabilities.
    As in other transactions, you can create the ledger on the fly by pressing Alt+C. Alternatively, press Alt+G (Go To) > Create Master > type or select Ledger > and press Enter
  4. Enter the amount in the Debit column.
  5. Credit the VAT ledger.
    As in other transactions, you can create the ledger on the fly by pressing Alt+C. Alternatively, press Alt+G (Go To) > Create Master > type or select Ledger > and press Enter.
    • Enter the Rate and Assessable Value in the VAT Details screen.
    • Press Enter to return to voucher screen.
  6. Set the option Provide VAT Details to Yes, and enter the relevant details.
    Note: The option Provide VAT Details is provided as per state specific requirements of VAT/CST forms and annexures. In this example, Bihar is selected as the State.
  7. Enter Narration, if required. The journal voucher appears as shown below:
  8. Accept the screen. As always, you can press Ctrl+A to save.
The states with Increase of Output Tax available as the Nature of Adjustment are given below:
State Name
Additional Details
Voucher Entry
Assam
Debit: Income/sales ledger.
Credit: VAT ledger.
Bihar
Advance Tax
Debit: Ledger grouped under Current Liabilities.
Credit: VAT ledger.
Chandigarh
Not Applicable
Debit: Expenses ledger.
Credit: VAT ledger.
Trade Discount
Debit: Sales ledger.
Debit: VAT ledger.
Credit: Party ledger.
Dadra and Nagar Haveli
Bad Debts Recovered
Debit: Cash ledger.
Credit: Income ledger.
Credit: VAT ledger.
Other Adjustments
Debit: VAT ledger.
Delhi
Bad Debts Recovered
Debit: Cash ledger.
Credit: Ledger grouped under Indirect Incomes.
Credit: VAT ledger.
Change EI/E2 Sales
Credit: VAT ledger.
Other Adjustments
Debit: Party ledger.
Credit: Sales ledger.
Credit: VAT ledger.
Gujarat
Sales to Commission Agent
Debit: Ledger grouped under Current Assets.
Credit: VAT ledger.
Credit: Additional tax ledger.
Kerala
Not Applicable
Credit: VAT ledger.
Adjustment Against Arrears
Credit: VAT ledger.
Odisha
Debit note issued by seller (insufficient VAT in purchase)
Credit: VAT ledger.
Puducherry
Other Adjustments
Debit: Party/cash ledger.
Credit: VAT ledger.
