HomeTallyPrimeLicensingIP Addresses/URL in Firewall or Proxy Exceptions
 PDF
Add IP Addresses, URLs, and Hostnames to Windows Proxy or Firewall Exceptions List
When you work in a secured network environment Proxy or Windows Firewall will restrict requests and responses from certain IP addresses or hostnames. To overcome this, whitelist these IP addresses, URLs, and hostnames by adding them to Windows Proxy or Firewall Exceptions list. As a result, you can bypass Proxy or Firewall when accessing these addresses.
To seamlessly enjoy Tally Software Services (TSS) and other services like e-Way Bill, e-Invoice, banking, Tally product licenses, TallyShop, customer portal, and so on, list the required URLs as exceptions in the Windows Proxy and Firewall. Thereafter, Proxy or Firewall will not block the services from such URLs, and will allow requests and responses from such servers.
Adding IP addresses, URLs, and hostnames to Windows Proxy or Firewall Exceptions will help in resolving potential issues in:
  • Connecting company to Tally.NET
  • Opening TallyShop
  • Connectivity for synchronisation
  • Product update (Capsule download)
  • Activation or reactivation of license
You may add either the URL or the IP address in the Proxy or Firewall Exceptions list. In case you need to add the IP address, you can find the IP address using the URL.
List of IP Addresses, URLs, Hostnames, and Ports for Different Services
Whitelist the following URLs or hostnames and IP addresses in your Firewall or Proxy settings to seamlessly avail the services provided by Tally. For that, you have to identify the required IP addresses or URLs for the services you need and add them to Windows Proxy or Firewall Exceptions.
Tally Servers – Firewall Exceptions
URL Services
*.tallysolutions.com e-Way Bill, e-Invoice, License Service, TSS Renewal, TallyShop, Tally Reports in Browser, Customer Portal on Tally Website
*.tallyenterprise.com Synchronisation, Remote Access, Banking Services, Capsules for Product Update, TCS, TDS, Banking, and so on
If your firewall does not allow you to use wildcards like * in the Exceptions list, then you can add the specific URLs listed in the tables below. You just need to add the URLs for the services that you want to avail.
Tally Servers – Proxy Exceptions
URL Port Services
*.tallysolutions.com 80 License Service, TSS Renewal, TallyShop
*.tallysolutions.com 443 e-Way Bill, e-Invoice, Tally Reports in Browser, Customer Portal on Tally Website
*.tallysolutions.com 9009 Tally Reports in Browser
*.tallyenterprise.com 80 Synchronisation, Remote Access, Capsules for Product Update, TCS, TDS, Banking, and so on
*.tallyenterprise.com 9050 Synchronisation, Remote Access
In case your network policies do not allow you to use wildcards like * in the Exceptions list, then you can add the specific URLs listed in the tables below. You just need to add the URLs for the services that you want to avail.
Bharat Connect for Business
URL IP Address Port
api.tbcb.tallysolutions.com
Multiple IP addresses 443
e-Way Bill Services
URL IP Address Port
ewaybill.tallysolutions.com
(Applicable to TallyPrime Release 2.0 onwards)
e-Invoice Services
URL IP Address Port
einvoice.tallysolutions.com Multiple IP addresses 443
einvoice-demo.tallysolutions.com
(To use e-Invoice sandbox services)
License Service, TSS Renewal, and TallyShop
URL IP Address Port
experts.tallysolutions.com Multiple IP addresses 80
licensing.tallysolutions.com Multiple IP addresses 80
URL IP Address Port
browser.tallysolutions.com Multiple IP addresses 9009 and 443
browser1.tallysolutions.com 3.6.186.43 9009 and 443
browser2.tallysolutions.com 13.126.1.106 9009 and 443
browser3.tallysolutions.com 3.6.203.219 9009 and 443
URL IP Address Port
customer.tallysolutions.com Multiple IP addresses 443
iam.tallysolutions.com Multiple IP addresses 443
Synchronisation and Remote Access
URL IP Address Port
tallynet.tallyenterprise.com 180.179.20.215 80
tallynet.tallyenterprise.com 180.179.20.208 80
trb001.tallyenterprise.com 180.179.20.103 80
trb002.tallyenterprise.com 180.179.20.141 80
trb003.tallyenterprise.com 180.179.20.153 9050
trb004.tallyenterprise.com 180.179.20.154 80
trb005.tallyenterprise.com 180.179.20.155 80
trb006.tallyenterprise.com 180.179.20.194 80
trb007.tallyenterprise.com 180.179.20.213 80
trb008.tallyenterprise.com 180.179.20.214 80
trb009.tallyenterprise.com 203.112.143.45  9050
URL IP Address Port
cds001.tallyenterprise.com 180.179.20.172 80
cds002.tallyenterprise.com 180.179.20.209 80
Banking Services
URL IP Address Port
bis001.tallyenterprise.com 180.179.20.29 80
bis002.tallyenterprise.com 180.179.20.31 80
Find IP Address Using URL
You may add either the URL or the IP address in the Proxy or Firewall Exceptions list. In case you need to add the IP address, you can find it using the URL.
For example, you can find the IP address for e-Way Bill or e-Invoice services using the following procedure. However, this procedure does not apply to the e-Invoice demo URL used for sandbox services.
  1. Open Command Prompt.
    Either search for Command Prompt or enter cmd in the Windows search bar and select Command Prompt.
    If you do not see the Windows search bar, click the Start button at the bottom-left corner of your desktop.
  2. In the Command Prompt window, enter nslookup ewaybill.tallysolutions.com or nslookup einvoice.tallysolutions.com.Find IP Address
    Address – Refers to the IP address of your computer.
    Addresses – Refers to the IP address of the URL provided.
Add Tally Server URLs to Windows Proxy Exceptions
  1. Go to Control Panel > Internet Options > Connections.
  2. Click LAN Settings > Use proxy server for your LAN > Advanced.
  3. Specify the proxy address to use.
  4. Under the Exceptions section, type *.tallysolutions.com:80; *.tallysolutions.com:443; *.tallysolutions.com:9009; *.tallyenterprise.com:80; *.tallyenterprise.com:9050;, as shown below.
    Add IP Addresses/URLs/Hostnames to Windows Proxy Exceptions
  5. Click OK.
  6. On the Local Area Network (LAN) Settings screen, click OK.
  7. On the Internet Properties screen, click OK.
    Hereafter, the Proxy will allow requests and responses from all Tally servers under tallysolutions.com and tallyenterprise.com.
You can follow the same steps to add specific URLs for the services that you want to avail. Refer to the List of URLs, IP Addresses, and Ports for Different Services for the complete list.
Add IP Addresses or URLs in Third-Party Firewall Exceptions
In case you are using third-party tools for network security, then you have to add the required IP addresses, URLs, and hostnames to the Firewall Exceptions. Refer to their official sites for the required procedures.
Helpful?
