Record Excise Debit Note for Purchase Returns (Excise for Importer)
When a purchase has been made and if the goods are returned cause they are damaged or any other reason, then a purchase return has to be recorded. In TallyPrime a debit note is used to record a purchase return.
To record an excise debit note for purchase returns
  1. Gateway of Tally > Vouchers > press F10 (Other Vouchers) > type or select Debit Note.
    Alternatively, press Alt+G (Go To) > Create Voucher > press F10 (Other Vouchers) > type or select Debit Note.
  2. Press Ctrl+H (Change Mode) > select Excise Invoice.
  3. Enter the Original Invoice Number and Date.
  4. Select the party name from the List of Ledger Accounts.
  5. Select the party ledger and provide the required information in Party Details screen.
  6. Press Ctrl+A to go back to the debit note.
  7. Select the Purchase Ledger from the List of Ledger Accounts.
  8. Select the item from the List of Stock Items.
  9. Enter the Quantity, Rate, and Amount in the Stock Items Allocations screen.
  10. Press Ctrl+A to go back to the debit note.
    The completed excise debit note appears as shown below:
  11. Press Enter to save.
