Style
The definition Style can be used in the Field definition only. This definition determines the appearance of the text being displayed/printed, by using a corresponding font scheme, i.e., Bold, Italic, Point Size, Font Name, etc. The Style attribute in Field Definition is used to format the appearance of the text appearing within the Field, both in Display and Print mode, provided the Print Style attribute is not used within the current Field.
Syntax
Font     : <Font Name>
Height  : <Font Height in Point Size>
Bold     : <Logical Formula>
Italic     : <Logical Formula>
Example
[Style: TSPL Style]
Height : Grow 25%
Bold   : Yes
Italic : Yes
In this example, the Style definition named TSPL Style is used to control how the text appears within a field. It defines formatting properties such as size, weight, and style to enhance the visual presentation of text. The attribute Height : Grow 25% increases the text size by 25% compared to the default height, while Bold : Yes makes the text appear thicker for emphasis, and Italic : Yes slants the text to give it a stylized look.
➥ Click here to download Style Sample
Attributes
Selecting the right font for your report is just like picking the perfect outfit for an event. It sets the tone for the report. By specifying the supported Font name, you give your text its own unique style, whether sharp and professional or casual and friendly. A great font keeps readers hooked! In Tally, we use Arial to give reports a clean, professional look that’s easy on the eyes.
Syntax
Font: <Font Name>
Where,
<Font name> decides the type of font.
Example
Font: “Arial”
This defines a new style called TSPL Style. It makes the text have “Arial” font wherever this style is applied.
Sometimes, certain text needs to shout, “Hey, look at me!”. See, you just focused on the text. That’s where the Bold attribute comes in. It gives your important info some extra muscle, making it pop out clearly on your reports or screens. Whether it’s headings, key numbers, or anything that needs the spotlight, bold makes it impossible to miss.
Just like in TallyPrime, where every heading and title flexes its boldness to guide you like a friendly neon sign!
Syntax:
Bold: <Logical Formula>
Where,
<Logical Formula> is a formula that returns Yes or No, determining whether the font should be displayed in Bold style.
Example
[Style: TSPL Style]
Bold: Yes
This defines a new style called TSPL Style, it makes the text appear bold where this style is applied.
Choosing the right Height for your text is like adjusting the size of your outfit. It makes sure your text is easy to read without overwhelming the page. By specifying the Height attribute in the style definition, you control how tall your text appears, balancing readability with style.
Syntax
Height: <Measurement Formula>
Where
<Measurement Formula> is a formula that evaluates to a number representing the font size in points
Example
Height: 10
This defines a new style called TSPL Style. It sets the text height to 10 points wherever this style is applied.
Adding the right flair to your text is easy with the Italic attribute. It tilts your font gracefully, helping to highlight quotes, emphasize important points, or give your report a subtle touch of style.
Syntax
Italic: <Logical Formula>
Where
<Logical Formula> is a formula that returns Yes or No, determining whether the font should be displayed in italic style.
Example
Italic: Yes
This defines a new style called TSPL Style. It makes the text be shown in italics where this style is applied.
