Recipient should be SEZ for transaction SEZWOP
Cause
This error occurs when you try to generate an e-Invoice for a party with Registration Type as SEZ but it has GSTIN/UIN of a Regular party.
Resolution
- Press Alt+G (Go To) > Alter Master > Ledger > select the party ledger.
- In the Ledger Alteration screen, update the Registration type as Regular – SEZ and enter the GSTIN/UIN of the SEZ party.
- Press Ctrl+A to save the ledger.
Now, proceed to generate e-Invoice again.
