Invalid or Blank Supplier PIN Code | Invalid or Blank Supplier State Code | Invalid Consignee PIN Code | Invalid Consignee State Code
Cause
These errors occur when the State or Pincode are either not entered or are invalid in the Consignor or Consignee details.
Resolution
- Open the voucher in alteration mode.
- Set Provide GST/e-Way Bill details: Yes.
- In the Additional Details screen, update the Pincode.
- Press F12 (Configure) > Show Consignor Details (From) and Consignee Details (To): Yes.
- Update the correct State and Pincode under Consignor Details (From), Consignee Details (To), or both.
- Press Ctrl+A to save and generate e-Way Bill.
To know more, refer to the state-wise Master Codes.
