Saving Projects
In TallyPrime Developer, you can save the current file either in the existing format or a different format, or save all open files in the project.
To save a file
  • Go to File > Save File.
The file is saved in the current file, in the existing format.
  • Select Save File As to save another copy of the existing file with a different name, and at a different location. The new file will become the current file in the active window.
  • Select Save All Files to save all the files open in the Project Browser window.
  • Click Save File, or Save All Files to save a file or all files within the project. These options are also available on the standard toolbar.
Helpful?
