Executing Projects
For executing Tally from TallyPrime Developer, the parameters need to be set in Preferences. Click hereย  for more details.
To execute TallyPrime from TallyPrime Developer
  • Go to Build > Execute Tally, or press Ctrl+F5.
or
  • Right-click the project in the project explorer window, and click Execute Tally.
To list syntax errors in the code
  • Go to Build > List Syntax Errors or press Ctrl+Alt+F7.
The syntax errors found in the current project are displayed in the Build tab of the Output window.
Helpful?
