Explore Categories
 PDF
Creating Projects
You can create a new project and enter the corresponding project details.
To create a project
  1. Go to File > New Project or press Ctrl+Shift+N .
  1. Enter the details in the Project Details tab of the Project Properties window.
By default, location and name of the TCP file are the same as the file name of the project.
  1. Click Save to save the settings. A . tpj file is created with the given name. Alternatively, click Save and Build to save and build the project. It creates the .tcp file simultaneously.
Helpful?
