Variable Related Functions
$$IsSysNameVar
This function checks if the variable has a value which is a sysName like ‘Not Applicable’, ‘End of List’, etc. In case of repeated variables, if any one value is a non-sysname, it returns FALSE.
Syntax
$$IsSysNameVar : <Variable Specification>
Where,
<Variable Specification> is the simple variable path specification.
Example
$$IsSysNameVar:EmpVar
Here, $$IsSysNameVar returns YES if variable EmpVar has Sysname as value, else returns NO.
$$IsDefaultVar
This function determines if the content of the variable has a “Default” or blank as the value. This function is applicable only for Simple variables. In case of simple repeated variable, if any one value is non-default, then this is not a default variable, and the function returns NO.
Syntax
$$IsDefaultVar : <Variable Specification>
Where,
Example
[Field : DefaultVar]
Set as : $$IsDefaultVar:SVValuationMethod
$$IsDefaultVar returns YES if value of SV V aluationMethod is blank or Default, else returns NO.
$$IsActualsVar
This function checks if the content of the variable is blank or sysname or “ACTUALS”.
Syntax
$$IsActualsVar : <Variable Specification>
Where,
Example
$$IsActualsVar:SVBudget
YES is returned if the value of Variable SVBudget is Blank or Sysname or “ACTUALS”, else NO.
$$IsCurrentVar
This function checks if the content of t h e variable is Blank or Sysname or “ Stock in hand”.
Syntax
$$IsCurrentVar : <Variable Specification>
Where,
Example
$$IsCurrentVar:DSPOrderCombo
YES is returned if value of DSPOrderCombo is Blank or Sysname or Stock-In-Hand, else NO.
$$ExecVar
This fuction returns the value of a variable in the parent report chain.
Syntax
$$ExecVar : <Variable Specification>
Where,
Example
$$ExecVar:DSPShowMonthly
Function $$ExecVar returns the value of the variable DSPShowMonthly from the parent report.
$$FieldVar
This function returns the value of the field which is acting as a variable with the specified name.
Syntax
$$FieldVar : <Variable Specification>
Where,
Example
[Collection : GodownChildOfGodownName]
Type : Godown
Child of : $$FieldVar:DSPGodownName
In this example, $$FieldVar is used to fetch the value of the variable DSPGodownName whose value is modified in a field. This value becomes the value for the ‘ChildOf’ attribute.
$$ParentFieldVar
This function gets the field variable value from its parent report.
Syntax
$$ParentFieldVar : <Variable Specification>
Where,
Example
[Field : ParentFieldVar]
Set as : $$ParentFieldVar:SVStockItem
Here, the function returns field variable value from its parent report for the variable “SVStockItem”.
$$NumSets
It returns the number of columns in the report. It does not take any parameter. If the report is an auto report or sub report, it returns the number of columns in the parent of the auto/sub report. Number of set is the maximum number of values a repeated variable can hold in that report.
Syntax
$$NumSets
Example
[Field : CFBK Rep Col Total]
Use : Qty Primary Field
Set as : $$Total:CFBKRepParty
Border : Thin Left
Invisible : $$Numsets=1
In this example, the ‘Total’ column will be invisible if there is only one column in the report.
$$LowValue
This function c a n be used to get the lowest value in a set o f values in the repeated variable.
Syntax
$$LowValue : <Variable Specification>
Where,
<Variable Specification> is a simple variable specification.
Example
Let us suppose that the Repeat Variables in a Columnar Report are SVFromDate and SVToDate. Consider the following Field Definition in the same report:
[Field : VariableLowValue]
Use : Name Field
Set as : $$LowValue:SVFromDate
$$Lowvalue returns the lowest value in a set of values in the repeat variable SVFromDate.
$$HighValue
This function can be used to get the highest value in a set of values in the repeated variable.
Syntax
$$HighValue : <Variable Specification>
Where,
Example
Suppose that the Repeat Variables in a Columnar Report are SVFromDate and SVToDate. Consider the following Field definition in the same report:
[Field : VariableHighValue]
Use : Name Field
Set as : $$HighValue:SVToDate
$$HighValue returns the highest value in a set of values in the repeat variable SVToDate.
$$IsCommon
This function is used with repeated variable to check if all the values in the repeat set are same.
Syntax
$$IsCommon : <Variable Specification>
Where,
Example
Suppose the Repeat Variable in a columnar report is SVCurrentCompany. Consider the following Field Definition in the same report:
[Field : VariableIsCommon]
Use : Logical Field
Set as : $$IsCommon:SVCurrentCompany
$$IsCommon returns YES if all values in SVCurrentCompany are same, otherwise returns NO.
