Explore Categories
 PDF
Integration Using XML Interface
TallyPrime has supported integration with web scripting languages such as ASP/Perl/PHP and other languages like VB or any environment capable of supporting XML and HTTP. Integration with these products is possible as XML import and export capability is built into TallyPrime.
Watch the below video to understand the collection capabilities to gather data from HTTP/Web services and the collection attributes that support integration.
In fact, TallyPrime delivers most of the functionalities of Web Services provided by Microsoft’s .NET framework. All TallyPrime data is accessible to any number of potentially disparate systems through the use of Internet standards such as XML and HTTP. In other words, TallyPrime can communicate with any environment capable of sending and receiving XML over HTTP.
This chapter explains how TallyPrime will act as a server/client while it is connecting to external applications. The following figure shows the XML Messaging Format through external application/ Web services, acting TallyPrime as a Server/Client.
Watch the below video to know the procedure to push/pull data from Tally through an XML interface.
Watch the below video to know how to update data from and to Web Application using XML Request/Response Framework.
Helpful?
