Developer Guide for KSA e-Invoicing Generation Phase
e-Invoice enablement for the company and voucher type
To enable e-Invoicing for the company and a voucher type; new storage ‘IsEInvoiceKSA’ is introduced.
;; to Check e-invoice yes or no
[Field: IsEInvoice]
Use : Logical Field
Set : $IsEInvoiceKSA
Field name for an e-Invoice number
To store the e-Invoice number, new storage and a field have been introduced.
;; to get e-invoice Number
[Field : KSA eInvoice Number]
Use : NameField
Set : $VcheInvUniqNo
New part for QR code
To print the QR code, a part is added to the existing GCC invoice for Saudi Arabia customers. Developers need to add part eInvoice QR Code.
[Part: eInvoice QR Code]
;; Use Below System Formula to get QR Code Information in Print Format
QR Code : @@EInvoiceQRCodeKsa : Yes
Line : eInvoice QRC Details
Width : 35 mms
Height : 35 mms
Customising Invoices
Since there have been many changes at Sales Color, direct changes to Sales Color has been restricted. To make changes or for new invoices, changes should be triggered from Printed Invoices.
Example
[#Form : Printed Invoice]
Add: Switch: At Beginning: VCH Print Format : New Print Invoice : @@IsSales
[!Form: New Print Invoice]
;; Delete All Part And Page Size
Delete : Part
Delete : Top Part
Delete : Bottom Part
Delete : Page Break
Delete : Width
Delete : Height
Delete : Space Bottom
Delete : Space Top
Functions introduced for integration
$$GetHash
The function $$GetHash to retrieve hash value in a field, and it takes six parameters.
Syntax
$$GetHash:<VoucherNumber>:<VoucherTypeName>:<VATAmount>:<TotalInvoiceAmountIncluingVAT>:<EntryDate>:<EntryTime>
$$SaveHash
This function is to save the value of the voucher. This function takes one parameter. This function should be called if there are no errors while importing.
Syntax
$$SaveHash: <EncodeHashValue>
Example
[Function: Import eInvoice Vouchers]
Variable : HashVar : String
00: New Object: Voucher
/* Call GetHash function before saving voucher object and save the value in variable. ;; This Function needs 6 mandatory parameters */
01 : Set : HashVar :$$GetHash:##VoucherNumber:##VoucherTypeName:##VATAmount: + ##TotalInvoiceAmountIncludingVAT:##EntryDate:##EntryTime
02 : Save Target
/* After saving voucher call SaveHash function. However, the value of hash should be saved only if there is no error. Hence we shall call the SaveHash function based on a condition i.e. SaveHash function should be called only when there is no error. To check error we are using $$LastError */
03 : Do If: ($$IsEmpty:$$LastError) : Call: SaveHash:##HashVar
– Function GetHash and SaveHash are additional functions developed for this utility only, hence these functions will not be available in the Function browser of TallyPrime Developer.
– These Functions will be discontinued from the integration phase, effective from KSA e-invoicing Release 6.2 onwards.
